Remote Control |
Art-Net Remote Art-Net Remote is a way to control the MADRIX software remotely. Learn more about this topic in the chapter Art-Net Remote (Input).
Control Buttons A limited option to control the PLEXUS is to use the control buttons on the device during stand-alone playback. For more information, see Control Buttons.
DMX-IN DMX-IN is a way to control the MADRIX software remotely. Learn more about this topic in the chapter DMX-IN (Input).
Extension Port The extension port is another option for remote control, when connecting external units to the port. For more information, see Extension Port.
Direct Remote Control Of The Device Via DMX Or Art-Net Introduction You can send DMX or Art-Net values directly to the MADRIX PLEXUS. In this way, you can control the PLEXUS remotely using a certain set of remote functions (as listed below). The PLEXUS will react to incoming DMX or Art-Net values and perform certain actions as a result. These remote control options are available independently of DMX-IN or Art-Net Remote, both of which will allow you to control the MADRIX software instead. With Remote Control via DMX or Art-Net you can directly communicate with the PLEXUS unit. Remote control via DMX means that you will connect an external DMX unit to one of the XLR ports of the MADRIX PLEXUS. The occupied port will no longer be available for DMX-OUT (output). Remote control via Art-Net means that you will connect an Art-Net unit to the Ethernet port of the PLEXUS. Both XLR ports will then be available for DMX-OUT (output).
Settings Of The Device Navigate to the menu 'Remote Control' > 'Remote Options'. 'Receive Via' - Specifies the source of remote commands. You can choose to receive remote commands via DMX, via Art-Net, or to turn remote control off. You may change the settings in this menu, on the device (How To Edit Values). You can also configure the settings in the PLEXUS Configuration window in MADRIX. For more information, see Managing Devices Further.
List Of Functions This list includes all available remote functions and describes their functionality. Most of these functions are self-explanatory and have been described in the various PLEXUS menus. The following DMX channels are based on the default 'Start Channel' with a value of 1. If you would like to use a different Start channel, the DMX channels will change accordingly.
Intensity Groups Eight Intensity groups are shown in the above list, four of them are available for active use with MADRIX. This is a feature mainly available for Direct Remote Control. An Intensity Group includes all color values (0 to 255) for a single color. Intensity Group 1 controls the color channel Red. Intensity Group 2 controls the color channel Green. Intensity Group 3 controls the color channel Blue. Intensity Group 4 controls the color channel White. Example: You may wish to exclude Red color values from your visual effects via Remote Control. Using the Remote Command 13 (Intensity Group 1), you can choose to reduce the Red color channel to 0, for example. In this way, the PLEXUS will continue to output your visual effects, but completely without Red. You can also change settings for the Intensity groups in the menu 'Stand-Alone' > 'Intensity/Speed'. If you choose to control Intensity Groups for your Master interface (Master-Slave Synchronization), Slave interfaces can have their Intensity Groups controlled as well, when this option is selected in the Sync menu ('Network' > 'Sync').
Monitor Remote Navigate to the menu 'Remote Control' > 'Monitor Remote'. Use this menu to monitor and check incoming DMX data for Remote Control (DMX 1 or DMX 2). All 20 channels can be monitored using hexadecimal values.
Resetting Remote Control Settings When you are using Direct Remote Control, you are changing settings of the device directly. Of course, you can reset these settings back to original values.
Important Information When using Direct Remote Control, please be aware of other settings of the PLEXUS device. Please pay special attention to the menu 'Network' > 'Art-Net'. Art-Net -> DMX 1 and Art-Net -> DMX 2 specify if incoming Art-Net data is routed to the corresponding XLR port (DMX 1 or DMX 2). DMX 1 -> Art-Net and DMX 2 -> Art-Net specify if the corresponding XLR port is used for DMX-IN and if those incoming values should be broadcasted to the Art-Net network (Art-Net Remote).
Web Server Introduction The PLEXUS provides an integrated web server.
Using A Web Browser 1) Connect your PLEXUS as well as the remote device accessing the PLEXUS to a network (USB will not work). 2) Open a web browser and type in the IP address of your PLEXUS. The IP address can be found and changed in the PLEXUS menu 'Network' > 'IP Address'. 3) Once loaded, the page will show an interactive illustration of your device for remote control. The graphical interface represents the menu of your PLEXUS in real time. In this way, you can use various devices (such as smartphones, tablets, etc.) to control your PLEXUS remotely. Please note: Make sure to use one and the same network and check if the PLEXUS device settings and the operating system settings of the remote device are correct.
Using The PLEXUS Configuration Dialog 1) Connect your PLEXUS as well as the remote device accessing the PLEXUS to a network (USB will not work). 2) In MADRIX go to the menu 'Tools' > 'PLEXUS Configuration' (or 'Ctrl+Alt+P'). 3) Press 'Scan' to search for your connected devices. Please note: Make sure to use one and the same network and check if the PLEXUS device settings and the operating system settings of the remote device are correct. 4) Select your device in the list. 5) Press 'Call' (Network connection required). 6) Your standard web browser will be opened automatically and load a page. 7) Once loaded, the page will show an interactive illustration of your device for remote control. The graphical interface represents the menu of your PLEXUS in real time. In this way, you can control your PLEXUS remotely.
Interactive Remote Control The interactive demonstration in your web browser will look like this: Use your mouse (trackball, touchscreen, or any other input device) to click on the buttons •, –, —, ˜, 'OK', and 'EDIT' for navigation and editing. If the illustration is not updating its information, simply refresh your browser when necessary.
