Log
<< Click To Display Table Of Contents >> You Are Here: Using The Software > Log |
The Log view shows all important occurrences for the MADRIX HARDWARE MANAGER itself and its communication with devices.
Such logging and subsequent files are very helpful for technical support and assistance, but aren't necessarily required for the general use of the software. Still, it can provide you with valuable information and feedback for troubleshooting.
▪By default, the log view is hidden.
▪To show it, enable it in the menu View > Log
▪Severity - Allows you to filter only for specific kinds of information [including Info, Warning, Critical, Fatal].
- A specific severity level includes information for its own level as well as all higher levels.
Timestamp |
Shows the local time when the status message occurred [YYYY/MM/DD HH:MM:SS]. |
Severity |
Shows the classification for messages. |
Module |
Shows the software module [as information for the developers]. |
Message |
Contains the contents and main information of the status message. |
Clear Log Messages |
Removes all logged items from the list. |
Show Log File Directory... |
Opens the folder on your computer that holds saved log files. This directory also contains a link to another directory for user-mode dumps in case of software crashes. |
Copy Cell To Clipboard |
Copies the currently selected cell [that is, single information] into the clipboard/temporary memory. |
Copy Rows To Clipboard |
Copies the currently selected line or lines [that is, all text and information] into the clipboard/temporary memory. |
Export List... |
Saves the entire, currently shown list/view/table as a preformatted text file. |
▪Search - Enter any text in order to search all items in the list.
- For example: mess:IP shows all lines that include IP device information by referencing the column Message, for example.
A new log file is created with each software start.
In addition, you can set up further settings for the Log in the Options.
Learn more »Logging
MADRIX HARDWARE MANAGER allows you to choose which columns are presented in this view. You can decide which columns are hidden or shown.
Shown - A checkmark means that columns are shown. |
Hidden - No checkmark means that columns are hidden. |
Timestamp |
Shows or hides the Timestamp column. |
Severity |
Shows or hides the Severity column. |
Module |
Shows or hides the Module column. |
Thread |
Shows or hides the Thread column. |
Message |
Shows or hides the Message column. |
| MADRIX HARDWARE MANAGER User Manual 1.2. |
