Firmware Updates
You Are Here:  Technical Support >
Firmware Updates
It is highly recommended to update the firmware should a new firmware version become available.
You can update the device in different ways.
Important Information
▪Note: Make a backup before updating (or downgrading) the firmware of your MADRIX AURA devices!
[In this way, you can reload your settings after updating. New firmware versions may introduce new features, which requires a reset of all parameters. Downgrades to older firmware versions usually require a full reset to factory default settings.]
MADRIX HARDWARE MANAGER
To update your devices, please use the separate MADRIX HARDWARE MANAGER software.
Learn more »Using MADRIX HARDWARE MANAGER [USB / Ethernet]
Available Firmware Updates
Sorted in descending order.
Latest Version
Highlights
AURA Firmware
4.01.2791
Release Date
July 2026
▪Added support for an acoustic beeper for hardware revision 1.11 (#13353).
▪Now logs how long it takes for the SD-Card to be formatted in the Logfile (#13287).
▪Optimized system resources (#13288, #13344).
Bootloader
1.09.2791
▪Added support for an acoustic beeper for hardware revision 1.11 (#13355).
▪Added support for hardware revision 1.11 (#13384).
AURA Firmware
4.00.2776
Release Date
July 2026
▪Attention!
Art-Net Universe 0x00 has been deprecated according to the Art-Net specifications. Start universe 0 used to be 0x00 and referenced as 1 on the Web Configuration of the device in the past. Now, Start Universe 1 and thus universe numbering on the device starts at 0x01, instead of 0x00.
oThis change is only applied after a Reset To Factory Default Settings [or for brand-new devices].
oSettings for the assignment of universes can be found in the menus Recording, Playback, and Remote of the Web Configuration.
oWhen updating from firmware version 3.X to firmware version 4.X, your current values will be shown reduced by 1 in order to not destroy your current workflow and configuration. For example, by default universes 1 – 32 [0x00 – 0x31] are set under Recording/Playback and will now be shown as 0 – 31 [0x00 – 0x31] after the firmware update. A Reset To Factory Default Settings will set them to 1 – 32 again, but note that this actually now results in universes 0x01 – 0x32!
oManually setting Art-Net Universe 0x00 is still possible. [If 0x00 is set and the Protocol changed from Art-Net to sACN and applied via Set, the State of the Port will be set from On to Off, since Universe 0 is not available in sACN.]
oIn order to double-check, hover with your mouse over a universe number to see the specific Art-Net universe in the tooltip!
o(#12721)
▪Added native support for OSC to be able to control MADRIX AURA remotely this way [OSC Feedback is not yet available] (#6391, #13263).
Please note: The Show Configuration ShowConfig.xml is not compatible with older firmware versions if OSC is activated/included.
▪Added the option Last Playback State At Last Played Cue under Settings > Startup > Autoplay (#6527).
▪Now uses the Device Name under Settings > General as the HTML Title for the Web Configuration (#12862).
▪Added support for hardware model 1.10 (#12458, #13270).
▪Improved IP ACL handling [network firewall] (#13052).
▪Optimized the Web Configuration (#13123, #13234, #13235).
▪Updated and optimized system resources (#12872, #12876).
▪Renamed Start Scene to Start Cue in the default remote event list (#12875).
▪Changed the maximum available number of characters for Short Name (Art-Net) under Settings > General from 18 to 17 (#12842).
▪Fixed an issue with IGMP membership handling for multicast groups (#12943).
▪Fixed a critical error that could cause the device to become unresponsive when receiving network traffice that is not control data (#13088).
▪Fixed that sACN universe 64000 could be set via the Network Configuration file [NetConfig.xml] (#13195).
Bootloader
1.08.2776
▪Now sends out an Art-Net PollReply after starting and remaining in the bootloader (#7981).
▪Now provides the MAC address over USB/network (#13278).
▪Fixed that a bootloader flash update could fail in certain cases (#12008).
AURA Firmware
3.05.2606
Release Date
January 2026
▪Now supports the Preview Flag of Streaming ACN [sACN] to discard received data that is intended for visualization purposes only (#12731).
▪Uploads via the web browser are now processed case-sensitive (#12791).
▪Now stops playback in case of deleting Scenes via the – button, as was already the case when using the trash button to delete all at once (#12806).
▪Fixed a refresh issue of lists for Scenes/Cues/Timers/Events when deleting all items via the – button (#12809).
AURA Firmware
3.04.2585
Release Date
November 2025
▪Web Configuration: Added a fade animation between Scenes to the Operating Panel to indicate the fade/overlap of Scenes if your Cue List uses a Fade Type and Fade-In Time (#9687, #12606).
▪Web Configuration: Added automatic network tools under Settings regarding sACN and the Internet Group Management Protocol, which include sending IGMP Query, IGMP Report, Gratuitous ARP automatically (#11121).
▪Optimized the Save icon regarding readability (#12459).
▪Improved performance when setting parameters via the Web Configuration (#12498, #12500, #12535).
▪Fixed that sACN output could flicker during playback when sACN output universes and sACN input universes for recording were assigned to the same universes (#11216).
▪Fixed incorrect values shown for the currently used capacity of SD cards by correctly rescanning the file-system data (#11347).
▪Fixed a missing icon under the macOS operating system by replacing it with a similar ones (#12487, #12492).
▪Fixed that IGMP Group Memberships were not always fully left when setting a recording port to sACN during playback (#12493).
AURA Firmware
3.03.2716
▪Web Configuration: The new DMX Watcher shows live data the device is currently recording, playing back, or receiving for remote control (#6502, #12342, #12429, #12437).
▪Web Configuration: Added quick links via a button to monitor ports in the DMX Watcher for the menus Recording, Playback, and Remote (#12342, #12429).
▪Web Configuration: Added menu Device List to search for available Art-Net devices in the network (#12321).
▪Web Configuration: Added a new dialog to quickly select available IP addresses for Unicast Targets under Playback (#12361, #12412).
▪Web Configuration: Improved the icon used to link to Unicast IP addresses under Playback (#12394).
▪Web Configuration: Added a new Keypad test under Information > Service Functions in order to test the functionality of the physical hardware buttons (#12378).
▪Renamed the provided default Scenes to reflect RGB [with 510 channels] or RGBW data [with 512 channels] (#7224).
▪Renamed Highlight Device to Locate Device under Information > Service Functions (#12377).
▪Renamed Channel Mask 'Assign All Channels To Intensity Group 1–8' to 'Intensity Group 1–8 (All Channels)' (#12457).
▪Network packages are now being filtered to only process applicable Art-Net and sACN packets, which substantially increases the performance when recording Broadcast data and allows receiving a high number of DMX universes with high frame rates; and also ensures responsiveness of the Web Configuration and data reception over Ethernet in data-intense environments (#9924, #12128, #12428).
▪Improved reliability of automatically reloading of the configuration after uploading files via the Web Configuration (#11680).
▪Improved playback reliability (#12015).
▪Optimized icons and icon sizes for readability and to decrease file sizes (#12413, #12415, #12416).
▪Streamlined HTML source code (#12369).
▪Made sure that Remote Event Settings that are not available for the chosen HTTP Type are not shown (#12374).
▪Timer Type Cycle now works correctly again (#12348).
▪Fixed a missing closing tag in the HTML source code under Recording (#12359).
▪Fixed an incorrect icon size in the Log Panel (#12414).
▪Fixed a critical issue that could halt a device when being controlled remotely via Art-Net or sACN as a Master (#12432).
AURA Firmware
3.02.2464
▪Web Configuration: Added a quick link via an arrow button to call up Unicast IP addresses set up under Playback (#11750).
▪Now supports the RDM command RESET_DEVICE to reboot the system remotely via 0x01 WarmStart and 0xFF ColdStart (#12049).
AURA Firmware
3.01.2433
▪Fixed an issue that did not allow files to be uploaded that have 4k in size or more and whose size can be divided by 4k without remainder (#11885).
AURA Firmware
3.00.2417
▪Web Configuration: Added download and upload functionality for files via the web browser under Scenes > Scene File List (#6322, #6362).
▪Web Configuration: Added the playback direction the help of arrow symbols as quick overview under Cue List > Cue List Scenes (#10073).
▪Web Configuration: Added a back button for more subpages (#10789).
▪Web Configuration: You can now download the Network Configuration [NetConfig.xml] and Show Configuration [ShowConfig.xml] via your web browser under Settings > Backup > Execute Functions (#6362).
▪Now shows Endless in the Cue List Scenes instead of None for scenes that should repeat endlessly (#10073).
▪Now provides information about the bootloader version of the device over RDM [Parameter: Boot Software Version] (#10798).
▪Now includes the Network Gateway set up in the settings of the device when sending an ArtIpProgReply (#11037).
▪Optimized internal memory management (#9941).
▪Streamlined how settings are written to and read from the Show Configuration file (#10791).
▪Changed the operation code that is sent for the Gratuitous ARP to 2 and target MAC to normal broadcast (#11096).
▪Updated internal development tools (#11212).
▪Now shows the memory unit based on powers of 2 for RAM Information > Status Information under with binary prefixes, such as kibibyte (#11167).
▪Fixed an issue that listed an error for Remote Actions incorrectly as an error for Timer Actions (#10805).
▪Fixed an issue that did not show the Uptime correctly under Information > Status Information (#11248).
AURA Firmware
2.11.2495
Release Date
August 2024
▪Fixed an issue with internal memory management that could lead to various critical errors (#11083).
AURA Firmware
2.10.2320
Release Date
July 2024
▪Fixed an issue that introduced asynchronicity into the Master-Slave Synchronization after two seconds (#10829).
▪Fixed an issue that used the incorrect SlotCount to check the name length when setting the Device Label over RDM (#10835).
▪Fixed an issue that reported a detected maximum for RAM although it had not been defined as being supported over RDM (#10837).
AURA Firmware
2.09.2249
▪Added an IP ACL [network firewall] in order to filter network traffic that the device does not need to process or even check for possible processing (#10771).
▪Updated network components of the device firmware (#10766).
▪Web Configuration: Added NetBIOS functionality and information in the Device Information section to find and connect to devices using the NetBIOS name instead of the IP address (#10173).
▪Web Configuration: Designed the IP address in the Device Information section as a click-able link (#10239).
▪Web Configuration: Improved the NetBIOS functionality by writing out the full address for web browsers (#10357).
▪Web Configuration: Now shows the available RAM [current, total, and percentage] in the Status Information (#10652).
▪Art-Net 4: Added Squawking to the PollReply for better device identification in [software or hardware] controllers who support this feature (#10585).
▪Now automatically sends an Gratuitous ARP around every 25 seconds to make sure that the Ethernet connection is kept alive (#10809).
▪Improved discarding of ArtRdm draft packets by additionally checking the ArtRdm version flag (#10362).
▪Now provides information about the Memory of the device [RAM] over RDM [as sensor] (#10637).
▪Fixed an issue with the 'Node Report' field of the Art-Net implementation (#10369).
▪Fixed a potential issue when calling a password-protected Web Configuration for the first time without login information (#10459).
▪Fixed an issue that could remove Timers Events, Remote Events, or Scenes when changing the position of list entries in the Web Configuration (#10516).
▪Fixed a potential issue when duplicating Timer Events, Remote Events, or Scenes in the Web Configuration (#10519).
▪Fixed an incorrect RDM checksum validation (#10531).
▪Fixed minor CSS issues of the Web Configuration (#10552).
▪Fixed an issue with the file-name input pattern that included invalid characters in the regular expression (#10553).
▪Fixed an issue that resulted in the Web Configuration being unresponsive after a while when receiving too many network packets that were not meant for the device (#10732, #10762).
▪Fixed an issue that did not load the previously set Intensity of a Cue in the Cue List after a power cycle or reboot (#10769).
▪Fixed an issue that did not load the exact percentage values of Intensity or Speed of a Cue in the Cue List after a power cycle or reboot (#10769).
AURA Firmware
2.08.7499
Release Date
October 2023
▪Fixed an issue that produced incomprehensible text output in the beginning of a Logfile after a restart (#10156).
▪Fixed an issue that prevented devices to be consistently recognized at USB 3 ports (#10188, #10190, #10202).
Bootloader
1.07.7500
▪Fixed an issue that prevented devices to be consistently recognized at USB 3 ports (#10189).
AURA Firmware
2.07.7495
Release Date
September 2023
▪Units with less than 32 universes do no longer actively consider universes higher than their output count to determine at which frame rate to output (#9201).
▪Fixed an issue that continuously and without possible interruption triggered scenes set to 'Endless' Repeat with a playtime of less than the default Fade-In Time (#9700).
▪Fixed an issue that did not correctly play back scenes with a playtime of only 1 frame on Slave devices in a Master-Slave Synchronization (#10105).
▪Fixed an issue that did ignore the BindIndex via ArtAdress; resulting in users only being able to set the first universe via ArtAddress (#10138).
AURA Firmware
2.06
▪Fixed an issue that did not take into account the dates of the Event Validity of a Timer in certain cases (#10076).
▪Fixed an issue that could result in flickering output when setting Fade Type White or Cross for a scene set to Endless Repeat (#10091).
▪Fixed an issue that did start a new scene after stopping a scene with a playtime of only 1 frame and having it play longer than the regular playtime after pausing it (#10093).
▪Fixed an issue that did not show the elapsed time during recording on the Operating Panel (#10101).
▪Fixed an issue that could result in missing output data in certain cases when setting a Cue Speed of more than 100% (#10101).
AURA Firmware
2.05
▪Cues with 'Endless' Repeat are now shown with 'Endless' for Follow Cue in the Cue List (#10077).
▪The Logfile now includes additional information as to why a device was rebooted or reset to factory settings (#10058).
▪Fixed an issue that could result in devices automatically restarting when operating them in temperatures near or outside the specified operating range (#10064).
▪Fixed an issue that enumerated Timers with an +1 offset in the Logfile (#10078).
AURA Firmware
2.03
▪Fixed an issue that showed the Playback > Target always as disabled, even though it should be enabled in case of Unicast (#10030).
▪Fixed an issue that incorrectly deleted a PollReply Advanced (#10035).
AURA Firmware
2.02
▪Added extended support for MADRIX AURA 12 (#9653).
▪Added the option for Master-Slave Synchronizations to define the Timestamps Interval for Master devices and to enable/disable Timestamps synchronization for Slave devices (#10001, #10008, #10010).
▪Improved wording of the error message when reaching the maximum number of 1000 scenes for the Cue List (#9715).
▪Checkmarks for checkboxes are now shown in the correct green accent color (#9964).
▪The Logfile now includes information when special commands were executed using the web configuration (#9783).
▪Logfiles can now manually be rotated to start logging in a new file (#9980, #9982).
▪Important device information is written to the Logfile in regular intervals; instead of only at startup (#9999).
▪Fixed an issue that did not apply a Fade in rare cases when changing to the next scene (#9650).
▪Fixed a critical issue that would halt Slave devices when playing back a scene with the Master that was not available on the Slave (#9714).
▪Fixed an issue that did not allow to duplicate a Remote Event that included 'Intensity Group' Action and 'Input Value' Value Type (#9897).
▪Fixed an issue that did not trigger a command when changing from an Action with a 'Fixed Value' Value Type to an Action without a 'Fixed Value' (#9897).
▪Fixed an issue that could result in missing entries in the Logfile if the number of entries to be written at the same time was too high (#9981).
▪Fixed a critical issue that could cause older devices to stop sending data in rare cases (#9992).
▪Fixed an issue that caused synchronized playback of scenes in a Master-Slave Synchronization to fail for scenes with long durations of more than ~30 minutes (#9998).
▪Fixed an issue that did not stop scenes set to 'Endless' Repeat that were not set to also 'Ping Pong' Direction (#10002).
AURA Firmware
2.01.7474
▪Web Configuration: Added additional information about devices to the Logfile, mainly the current device settings (#9744).
▪Web Configuration: Added information about why devices restarted and made sure logfiles were saved explicitly before executing the restart (#9747).
▪Fixed an issue that tried to rename configuration files for backup purposes before checking if those files actually existed yet (#9202).
AURA Firmware
2.00.7470
Release Date
May 2023
▪Web Configuration: A Cue with Endless Repeat and Ping Pong Direction no longer fades when switching directions (#9477).
▪Web Configuration: The maximum speed for the device under Control - Live Control is now 200%; previously 1000% (#9497).
▪Web Configuration: The maximum speed for a Cue under Cue List - Cue List Editor is now 200%; previously 1000% (#9497).
▪Web Configuration: The maximum value for the Actions Speed Scaled, Speed Increment, and Speed Decrement under Timers - Timer Settings is now 200% (#9497).
▪Web Configuration: The maximum value for the Actions Speed Scaled, Speed Increment, and Speed Decrement under Remote - Remote Control is now 200% (#9497).
▪Fixed an issue that could introduce asynchronicity in Master-Slave Synchronization after having playback paused and started again (#6411).
▪Fixed a critical issue that could halt slave devices during startup when a master device was already sending sync commands for Master-Slave Synchronization (#8854).
▪Fixed an issue that could disrupt long runtimes (#9275).
▪Fixed an issue that could result in outgoing Scenes being stopped during a fade to the next Scene for certain Speeds after changing the Speed in the Control - Live Control > Output Panel (#9419).
▪Fixed a critical issue that could halt the device after receiving a large number of ArtsAdress pakets at once (#9475).
▪Fixed an issue that did not activate Highlight Device mode via ArtAddress (#9476).
▪Fixed unnecessary delays in processing Ethernet packets (#9481).
▪Fixed an issue that a file with 0 byte file size could not be deleted anymore (#9527).
▪Fixed a critical issue that could halt the device when playing back Scenes endlessly (#9640).
▪Fixed an issue that could omit the decimal place of Cues in case of whole numbers (#9651).
AURA Firmware
1.16.7447
Release Date
February 2023
▪Prevents browsers to incorrectly cache values for Output Intensity, Output Speed, and Intensity Groups (#9286).
▪Added the development hash to the firmware version to Information > Device Information (#9274).
▪Added a timestamp of the real-time clock to the logfile to show the actual runtime even in case of power loss (#9372).
▪Improved synchronized playback in a Master-Slave Synchronization (#9429).
▪Fixed deviating frame counts of 1 frame in a Master-Slave Synchronization (#7542).
▪Fixed a critical issue that could halt the web configuration of devices in a Master-Slave Synchronization after a few hours of playback (#8841).
▪Fixed an issue that caused a Master frame to be shown with incorrect brightness that was too high when starting a new fade while another fade was already in process (#9280).
▪Fixed an issue that did not allow to pause playback during a fade (#9254).
▪Fixed an issue that prevented Slave devices to record data correctly in a Master-Slave Synchronization (#9360).
▪Fixed an issue that could start a manual recording process even though devices were actively playing back scenes in a Master-Slave Synchronization (#9388).
▪Fixed an issue that could freeze devices in a Master-Slave Synchronization when quickly changing the speed during playback (#9402).
▪Fixed an issue that did not fully end scenes during a fade while changing the speed (#9418).
▪Fixed an issue that showed incorrect recording start times for consecutive recordings (#9438).
AURA Firmware
1.15.7433
▪Added support for UTF-8 character encoding to show file names; thus enabling support of basically characters of any language, such as Chinese (#6452, #8864).
▪Added an ArtSync Automatism for more granular usage of ArtSync in combination with sACN under Settings > Synchronization (#8698).
▪The bootloader version can now be provided by the firmware over USB (#8873).
▪The progress bar of the Live Control – Operating Panel now only shows the position in % for playback to avoid any deviating values when changing the Output Speed during playback (#8934/ #9064).
▪Added a symbol/icon to show that the SD card is write-protected/locked or that no SD card is inserted into the device for the Scenes, Cue List, and Timers (#8946).
▪Improved durability of the EEPROM by increasing the write timeout (#8996).
▪Improved reliability by ensuring that network settings are always properly saved (#9220).
▪Improved the recording process when receiving data with different frame rates on different universes, avoiding juddering records in case a universe was sent with low frame rates in case of sACN or Art-Net without ArtSync (#9230).
▪Added more information about the device and its state to the logfile at startup (#9262).
▪Streamlined internal error codes over USB and network communication (#9237).
▪Fixed an issue that did cancel the recording process when the file size reached 4 GB (#8809).
▪Fixed an issue that Slave devices did not continue the recording process when the file size reached 4 GB and a new file had to be created (#8821).
▪Fixed an issue that produced flickering when fading two scenes in Master-Slave Synchronization of scenes without ArtSync that included empty frames on Slave devices (#8842).
▪Fixed an issue that cause Fade Type None to flicker when using Master-Slave Synchronization (#8851).
▪Fixed an issue that Slave devices had 1 frame less than Master devices when using Post-Sync recording; which caused None-fades to be uneven for example (#8855).
▪Fixed an issue that did not correctly set the Scene Name from the source when using Network Records (#8859).
▪Fixed an issue that ignored the write-protection of the SD card in certain cases when working with files (#8861).
▪Fixed an issue that did not allow to download the logfile with the MADRIX HARDWARE MANAGER (#8869).
▪Fixed an issue that showed logfiles twice in the selection (#8871).
▪Fixed an issue that allowed directories with the file extension *.dxd to be added as a cue to the Cue List (#8891).
▪Fixed an issue that did not allow to change the month to anything else than September for the Timer Type Yearly (#8991).
▪Fixed an issue that did not allow to set the Day to 31 for a Timer (#8991).
▪Fixed a memory leak for certain routines (#9026).
▪Fixed an issue that would cancel a fade an switch to the next scene if the playback speed changed and then restored to normal again (#9059).
▪Removed a number of unnecessary logfiles entries (#9062).
▪Fixed an issue that did not send the default short name of the device (i.e. the IPv4 as string) when the Art-Net Short Name had been left empty (#9169).
▪Fixed an issue that did not provide enough multicast groups for 32 sACN universes plus 8 sACN remote universes (#9171).
▪Fixed an issue that did not allow to start recording while controlling the device remotely with 8 sACN remote universes (#9173).
▪Fixed issues that returned incorrect states when sending commands over USB (#9203).
▪Fixed quick flashes of the previous scene, when changing scenes while fading from one scene to another scene (#9219).
AURA Firmware
1.14.7416
MADRIX Version
MADRIX 5.5a
Release Date
July 2022
▪Added the setting to edit the ShortName identifier for Art-Net (#8167).
▪Added the setting to disable automatically adding scenes to the Cue List (#8217).
▪The active state of highlighting ports is now communicated by showing the buttons in green (#8573).
▪Now automatically reloads the configuration including files after uploading scene files (*.dxd) with the help of the MADRIX HARDWARE MANAGER (#8579).
▪Optimized the web-configuration page (#7930).
▪Massively decreased the time that is required to upload files over USB (#8050).
▪Scene File Details: Removed Frame Rate and Frame Count as they could show incorrect values for files that were not recorded with a constant frame rate (#8587).
▪Prepared the device to receive the Scene Name from the source when using Network Records (#6386).
▪The status and type of the SD card can now be queried over USB (#8747).
▪Optimized fast memory usage (#8730).
▪Fixed an issue that caused incorrect fades between scenes with different Fade-In Times (#7143).
▪Fixed an issue that incorrectly showed the File Time of recordings at 61 seconds in certain cases (#8337).
▪Fixed an issue with web browsers regarding the parsing of XML (#8507).
▪Reduced data traffic by removing unnecessary parts of specific requests when using the web-configuration page (#8516).
▪Fixed that the Fade-In Time did not match when starting a scene via the Cue List or remotely while another scene was still running (#8522).
▪Fixed an issue that displayed page numbers incorrectly when removing all scenes via the Delete All button under Scenes, Cue List, Timers, and Timer Events (#8232).
▪Fixed an issue that displayed page numbers incorrectly when removing all scenes via the - button in the Cue List and under Scenes (#8584).
▪Fixed an issue that could cause the device to become unresponsive since a reset of the switch could fail by disconnecting from and connecting to power again (#8691).
▪Fixed an issue that prevented Settings > Backup > Execute Function > Reload Settings For Recording, Playback, and eDMX Remote Ports From SD Card to work correctly (#8699).
▪Fixed an issue that used Action Stop instead of Pause in the default remote remote event list (#8702).
▪Fixed several issues with Remote Event Actions that used Increment or Decrement when reaching value 128 (#8703).
▪Fixed an issue that did not show the correct playback time for scenes during playback when the Speed was set to a value other than 100 (#8718).
▪Fixed an issue that added a fade for scenes set to endless repetition in case the Speed was set to lower than 100 (#8719).
▪Fixed an issue that did not initialize parts of the systems memory correctly after startup, which could lead to errors when trying to access the SD card after performing a factory reset with MADRIX HARDWARE MANAGER (#8729).
AURA Firmware
1.13.7413
MADRIX Version
MADRIX 5.5
Release Date
June 2022
▪Fixed an issue that remained at the last frame of a scene after a run for the total duration when setting Repeat to > 1 in the Cue List (#8381).
▪Fixed an issue that playback of scenes became asynchronous for Masters/Slaves the higher Repeat/the loop count was set due to a difference of 1 frame during recording (#8383).
AURA Firmware
1.11.7411
MADRIX Version
MADRIX 5.4h
Release Date
April 2022
▪Fixed a critical issue that did prevent Master-/Slave Recording from working (#8230).
AURA Firmware
1.10.7410
MADRIX Version
MADRIX 5.4g
Release Date
March 2022
▪Supports the Network Time Protocol (NTP) for clock synchronization (#6068).
▪Added Highlight to Network Playback Settings to directly test the connection to lighting fixtures (#7647).
▪Channel Masks can now be applied to each port/universe separately; instead of only one mask per device (#7931).
▪Improved the Channel Mask for user-defined configurations with additional functionality (#7631, #7927, #7932).
▪Added new presets for the Channel Mask (Assign All Channels To Intensity Group) (#7932).
▪Introduced file version 2.0 of the Channel Mask. For downward compatibility, devices can read file version 1.0 and file version 2.0 (#7956).
▪Added a command to be able to reload the ChannelConfig.xml of the Channel Mask over network (#7979).
▪Removed the unnecessary CSS class .bs for buttons in the Web Configuration (#8026).
▪Fixed an issue that incorrectly reduced the intensity during cross fades or white fades of endlessly repeated scenes (#7661).
▪Fixed slow writing speeds and reading speeds over network (#7746).
▪Fixed an issue that incorrectly sent output value 1 on the blue color channel when fading from red scene (255, 0, 0) to a green scene (0, 255, 0) in the Cue List (#7945).
▪Fixed an issue that did not update the web configuration when inserting an SD card that now held fewer files, cues, timers, or events than previously shown (#7979).
▪Fixed an issue that did not factor in the Master Intensity when Fade Type White was used in the Cue List and always increased the intensity to 255 during a fade (#8063).
▪Fixed an issue in the firmware and bootloader that showed incorrect states for the status LEDs of the second Ethernet network port of hardware revision 1.9 (#8076, #8084).
▪Fixed an issue that did not allow to output intensity value 127 and falsely sent out 2 instead of 1 (#8075).
AURA Firmware
1.09.7403
MADRIX Version
MADRIX 5.4f
Release Date
January 2022
▪Supports the RDM flag per universe/port according to the latest Art-Net 4 protocol revision 1.4dd2 (#7902).
▪Fixed an issue that would cause the web configuration to not react anymore in random cases (#7811).
▪Fixed a critical issue that could crash the device when recording to an SD card that was write-protected (#7824).
▪Fixed an issue that produced incorrect recordings when receiving from two different sources in case the IP addresses only differed in the last octet (#7833).
▪Fixed an issue that showed the Logfile view incorrectly in the web configuration (#7841).
▪Fixed an issue that incorrectly updated the device-configuration file on the SD card when selecting the Playback tab, although no changes were made to the configuration (#7842).
▪Fixed an issue that prevented playback after changing the write-protection state of the SD card as the device no longer tries to save the show configuration when no SD card is inserted or if it is write-protected or does not have enough free space (#7890).
▪Fixed an issue that calculated entered values for Power-Up Delay in milliseconds instead of seconds (#7917).
▪Fixed a critical issue that would halt the device when creating the ChannelConfig.xml (#7925).
▪Fixed an issue that would only use the Channel Mask of the first universe for all channels of all universes when using a custom ChannelConfig.xml (#7925).
AURA Firmware
1.08.7401
MADRIX Version
MADRIX 5.4e
Release Date
October 2021
▪Updated the system of the device (#7443).
▪Updated the network interface and optimized the timing of writing files to the SD card over network (#7443, #7467).
▪Prepared the firmware and bootloader for possible future hardware revisions (#7740, #7741).
▪Fixed an issue that only allowed to record 17 universes over sACN (#7663).
▪Fixed an issue that did not initiate a PollReply when changing the IP address using the web configuration page (#7667).
AURA Firmware
1.07.7398
MADRIX Version
MADRIX 5.4c
Release Date
July 2021
▪The Uptime of the device is now shown under Information > Status Information (#7312).
▪Improved the timing of sending an Art-Net PollReply when a network cable is connected to one of the Ethernet ports by adding a small delay in order for network switches to be able to route the packet (#7254).
▪Optimized internal files and data storage (#7276).
▪Streamlined internal controller communication (#7277).
▪Fixed that the Intensity buttons on the device now both operate with the same +/-26 values (#7255).
▪Fixed that the Locate flag is now set correctly in the Art-Net PollReply (#7259).
▪Fixed that ArtIpProgReply now correctly sets unused values to 0 (#7266).
▪Fixed an issue that did not allow to switch from Art-Net to sACN and back again under Recording - Network Recording Settings (#7332).
▪Fixed an issue that did not refresh the Web Configuration correctly or waited for buffered data to be written completely when formatting the SD card in certain cases (#7327).
▪Fixed an issue that did not report information about the ports in the PollReply over network (#7354).
▪Fixed an issue that reported incorrect temperature values via RDM (#7380).
▪Fixed an issue that did not provide the file name and file path over network (#7402).
▪Fixed an issue that did not allow to read a file over network (#7405).
▪Fixed an issue that reported the recording status incorrectly over network (#7431).
▪Fixed an issue that did not allow to read subdirectories on the SD card correctly over network (#7455).
▪Fixed an issue that did not allow to write files to the SD card correctly over network (#7463).
AURA Firmware
1.06.7396
MADRIX Version
MADRIX 5.4b
Release Date
May 2021
▪Added DMX_PERSONALITY and DMX_PERSONALITY_DESCRIPTION for improved RDM compatibility (#7146).
▪Improved and streamlined how the device replies to ArtTodData with Unicast, Directed Broadcast, or Limited Broadcast (#7006).
▪Art-Net Broadcast addresses and sACN Multicast addresses have always been fixed and are now also shown as disabled to prevent editing under Playback > Network Playback Settings (#6956).
▪Fixed an issue that replied to ArtTodControl/ArtTodRequest referring to the wrong Universe for RDM since it did not check if the Universe was correct first (#6948).
▪Fixed a minor issue that showed the tooltip of the Apply button within the confirmation message when changing the IP address of the device (#6970).
▪Fixed an issue that assigned the BindIndex incorrectly to the eDMX Ports for Remote Control (#6980).
▪Removed unnecessary CSS commands from the web interface (#7084).
▪Fixed an issue that did not check the RDM Destination UID sufficiently (#7121).
▪Fixed an issue that did not allow to change the values for Latitude and Longitude under Settings > Location (#7133).
▪Fixed an issue that only returned 12 bytes of the device name when requested over USB (#7187).
▪Fixed an issue that did not allow to save the ChannelConfig.xml to the SD card via its command (#7220).
AURA Firmware
1.05.7389
MADRIX Version
MADRIX 5.4a
Release Date
February 2021
▪Added support for hardware version/model 1.6 (#6418, #6657).
▪Added support for ArtRdm under Settings > RDM to be able to reply to RDM requests by an RDM controller over Art-Net with status and sensor data (#6596).
▪The default setting for Autosave under Settings > Backup is now On [instead of Off] (#6761).
▪It is now possible to number Universes automatically in reverse/descending order under Recording > Network Recording Settings > Network Recording Universes > Universe (#6325).
▪It is now possible to number Universes automatically in reverse/descending order under Playback > Network Playback Settings > Network Sending Universes > Universe (#6325).
▪It is now possible to number Universes automatically in reverse/ascending order under Remote > Remote Control > eDMX Remote Port Settings > Universe (#6325).
AURA Firmware
1.04.7384
MADRIX Version
MADRIX 5.4
Release Date
December 2020
▪Fixed an issue that the playback time of cues did not correspond to the record time of scenes if different frame rates were received on the different universes during recording (#6679, #6680).
▪Fixed a critical issue that could halt the device when changing the IP address with help of the MADRIX Device Configuration window (#6706).
AURA Firmware
1.03.7381
MADRIX Version
Release Date
November 2020
▪Renamed the settings to activate or deactivate Full Frames from Y/N to On/Off under Playback (#6589).
▪Fixed an issue that did not allow to set follow functionality for slave devices if all parameters were not checked (#6582).
▪Fixed an issue that did not allow to enter all possible numbers as IP address under Playback (#6595).
▪Fixed a critical issue that did not allow to record all available universes from a large number of senders by increasing the number of possible ARP requests (#6602).
AURA Firmware
1.02.7380
MADRIX Version
Release Date
October 2020
▪Added Toggle Pause for Timers > Timer Event Action > Action (#6458)
▪Added controls to adjust all ports at once regarding state, protocol, and universe under Remote > eDMX Remote Port Settings (#6422).
▪Added new actions for Timers and Remote Control, incl. Speed Increment, Speed Decrement, Intensity Increment, Intensity Decrement, Intensity Group 1 - 8 Increment, Intensity Group 1 - 8 Decrement (#6480).
▪Added a duplicate IP address feature to quickly set the same IP address for all ports under Playback (#6499).
▪It is now possible to stop playback of the cue list under Cue List > Cue List Scenes (#6384).
▪It is now shown if the device has been set as Master or Slave as Sync. Type under Live Control > Operating Panel (#6470).
▪Slave devices have functionality locked and disabled while a Master is actively controlling the group (#6494).
▪Added a logfile view under Information > Service Functions (#5993).
▪Added the option to download logfiles directly from the web configuration (#6518).
▪Changed the default value range from percent to DMX for Control > Output Panel > Intensity (#6186).
▪Changed the default value range from percent to DMX for Control > Output Panel > Intensity Group Panel (#6186).
▪Changed the value range from percent to DMX for Timers > Timer Event Settings and all Intensity-related Actions (#6186).
▪Changed the value range from percent to DMX for Remote > Remote Event Settings and all Intensity-related Actions (#6186).
▪It is now possible to switch from DMX to percent for Control - Live Control under Settings > Website > View Intensity In (#6186).
▪Renamed the Control Panel and Master Panel to Operating Panel and Output Panel to better differentiate towards Master-Slave Synchronization (#6470).
▪Renamed Scene to Cue in the majority of cases in order to clarify the connection to the cue list as several cues can be based on a single scene file, for example (#6423, #6443).
▪Renamed Toggle Play to Toggle Pause for Remote > Remote Event Settings > Action (#6458).
▪Only remote events that are set to active can be clicked and are shown in the HTTP Remote Control Check under Remote > Remote Event List (#6559).
▪The main menu now shows which item is currently selected (#6093).
▪It is now shown with the help of a red save icon if a configuration has been modified and that there are unsaved changes for the Cue List, Timers, and Remote Control (#6233).
▪Setting up access control via a login now requires explicit confirmation (#6392).
▪Changing the network settings, such as the IP address, now requires explicit confirmation (#6512).
▪Improved the playback synchronization of the Master-Slave Synchronization and fixed accompanying issues (#6383, #6492).
▪Improved the recording synchronization of the Master-Slave Synchronization and fixed accompanying issues; especially with lower frame rates (#6570).
▪Improved the recording and playback behavior of the Master-Slave Synchronization when devices are not receiving any incoming data by creating placeholder scenes (#6355).
▪It will now be checked if Valid Until is not an older data than Valid From and automatically set to Valid From if that is indeed the case (#6389).
▪Improved how the web panel access control is shown, implemented that the access restriction will now be disabled again if no username or password have been set, and added the option to remove the password again (#6421).
▪Added and improved various tooltips (#6388, #6443).
▪Improved various labels (#6443, #6568).
▪Fixed an issue that the web browser did not display SVG icons after a site refresh (#6326).
▪Fixed several user interface inconsistencies of Remote > Remote Event List > HTTP Remote Control Check (#6357).
▪Fixed an issue that did reset a yearly timer to the current month instead of the selected value under Timers > Timer Event Start Date (#6432).
▪Fixed an issue that showed the time incorrectly under Information > Status Information when the SD card in use returned an incorrect OID (#6453).
▪Fixed an issue that endless repetition of a cue in the cue list only worked for the first cue (#6454).
▪Fixed an issue that did not save the remote command Toggle Play in the show configuration(#6457).
▪Fixed an issue that could halt the device completely when receiving the ArtIpProg command (#6464).
▪Fixed minor issues regarding unwanted line breaks in the user interface (#6509).
▪Fixed an issue that applied an incorrect year when entering a past date under Timers > Timer Event Validity (#6510).
▪Fixed an issue that caused cues with White Fade Type and endless repetition to flicker under Cue List > Cue Settings (#6537).
AURA Firmware
1.01
MADRIX Version
Release Date
July 2020
▪Added support for MADRIX AURA 2 (#6268).
▪It is now possible to rename scene files under Scenes > Scene File Details (#6319).
▪It is now possible to delete single scene files from the SD card under Scenes > Scene File List (#5945).
▪It is now possible to delete all scene files from the SD card under Scenes > Scene File List (#6334).
▪Files that are used in the cue list will now be shown as linked files under Scenes > Scene File List (#6354).
▪Linked files that have been deleted will not be selected as source anymore under Cue List > Scene Details. A warning sign will be shown (#6368).
▪It is now possible to start playback of the cue list starting with the currently selected scene under Cue List > Cue List Scenes (#6320).
▪It is now possible to duplicate scenes under Cue List > Cue List Scenes (#6182).
▪It is now possible to move scenes up and down in the list under Cue List > Cue List Scenes (#6342).
▪It is now possible to remove all scenes from the cue list under Cue List > Cue List Scenes (#6334).
▪It is now possible to duplicate timers under Timers > Timer Event List.
▪It is now possible to move timers up and down in the list under Timers > Timer Event List (#6342).
▪It is now possible to delete all timers from the list under Timers > Timer Event List (#6334).
▪Timers are now shown as active or inactive with a green or red dot in the Timers > Timer Event List.
▪Timers can be set to Action > None to be used as a placeholder (#6360).
▪New timers are now set to Inactive and Action > None by default to prevent any triggering before the timer is configured correctly (#6360).
▪It is now possible to create custom, user-defined channel masks (#5974).
▪It is now possible to duplicate remote events under Remote > Remote Event List (#6183).
▪It is now possible to move remote events up and down in the list under Timers > Timer Event List (#6342).
▪It is now possible to delete all remote events from the list under Remote > Remote Event List (#6334).
▪Remote events are now shown as active or inactive with a green or red dot in the Remote > Remote Event List (#6361).
▪Remote events can now be set as Active or Inactive in the Remote > Remote Event Settings (#6361).
▪Remote events can be set to Action > None to be used as a placeholder (#6360).
▪New remote events are now set to Inactive and Action > None by default to prevent any triggering before the remote event is configured correctly (#6360).
▪Restoring the default settings under Remote > Remote Event List now requires additional user confirmation (#6369).
▪It is now possible to change the maximum brightness of the status LEDs on top of the device (#5994).
▪It is now possible to require a login in order to access the device's web configuration via username and password under Settings > Web Panel Access Control (#6392).
▪The time before reloading the website after a reboot or reset to manufacturer's default settings has been increased to 15 seconds to avoid unsuccessful reloads (#6251).
▪The current file system of the SD card and its cluster size are now shown under Information > Status Information (#6245).
▪It is now possible to use the Highlight Device functionality via the website under Information > Status Information (#6382).
▪Up to 10 logfiles are now automatically saved directly on the SD card for technical assistance (#5849).
▪Improved synchronization process for multiple devices and Master-Slave Synchronization (#6001).
▪Improved the recording process to ensure a synchronized recording start of multiple devices and Master-Slave Synchronization (#6263).
▪Improved saving processes to ensure responsiveness of the website (#6257)
▪File names can now include additional characters, such as (,),#,{,} (#6395).
▪Fixed an issue that did not save the Remote settings when using Autosave (#6124).
▪Fixed several issues when trying record for master and slave devices, while have Network Recording Universes deactivated for master devices, slaved devices, or both (#6223).
▪Fixed an issue that did not allow to continue playback after trying to play back a scene with a size of 0 bytes (#6254).
▪Fixed an issue that set all inactive timers to active after a restart of the device or reset to manufacturer default settings (#6289).
▪Fixed an issue that did not show error messages completely under Control > Control Panel (#6301).
▪Fixed an issue that played large scene files backwards very slowly instead of smoothly (#6304).
▪Fixed an issue that only allowed to play back *.dxd files, and excluded *.DXD files (#6353).
▪Fixed an issue that did not save and remember None for Follow Scene under Cue List > Scene Details after a device restart (#6390).
▪Fixed an issue that shortly made previous cues visible when skipping to the next cue (#6408).
AURA Firmware
1.00
MADRIX Version
Release Date
June 2020
▪Initial firmware release.
MADRIX AURA User Manual 4.01.
