▪Introduction
▪Overview
▪Context-Menu
▪Search
▪Customization
The Slots view shows all reported slots for the currently selected device.
Since this is specific to a device [as defined and implemented by the manufacturer], no information can be edited.
Usually and if available, slots represent the DMX personality of a device, that is which functionality is assigned to which channel [for example, Master Dimmer, Red Channel, Green Channel, Blue Channel, White Channel, Intensity, etc.].
Use the arrows in order to show these slots by expanding the view [or collapsing it back].
Offset
Represents the channel number of the device. It also shows primary and secondary slots. Secondary slots specify primary slots more precisely. [As defined by the RDM standard, these start with the index 0.]
Description
Shows a more in-depth explanation of the slot [as reported by the device].
Type
Shows the type of the slot [as reported by the device].
Default Value
Shows the default value of the slot [as reported by the device].
Context-Menu
Request Slot Information (Get:SlotInfo)
Sends a request to the device in order to manually update the provided slot information.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
▪Search - Enter any text in order to search all parameters in the list.
- For example: Desc:Int shows all lines that include intensity slots by referencing the column Description, for example.
Customization
Resize All Columns To Content
