▪Introduction
▪Overview
▪Context-Menu
▪Search
▪Options
▪Customization
RDM devices may include specific scenes. As such, you could say that they can have their own log implemented.
The Presets view shows all received scenes for the currently selected devices.
Preset
Shows the scene number that the device has stored [as reported by the device].
Fade-In Time
Shows the defined fade-in time for the current scene.
Fade-Out Time
Shows the defined down fade for the previous scene or active look.
Wait Time
Shows the defined time the device remains at the current scene before playing the next scene.
Programmed State
Shows if a preset scene is not programmed [0], if it is programmed [1], or if it can only be read since it was programmed by the manufacturer.
Context-Menu
Edit Preset Settings (Set:PresetStatus)...
Opens a new window to modify a preset.
Preset Number - Defines the scene number.
Fade-In Time (s) - Defines the fade-in time [in seconds].
Fade-Out Time (s) - Defines the down fade [in seconds].
Wait Time (s) - Defines the wait time [in seconds].
Confirm with OK. Or abort the process via Cancel.
Clear Presets (Set:PresetStatus)
Removes the currently selected presets.
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
▪Search - Enter any text in order to search all parameters in the list.
- For example: Desc:Vol shows all lines that include voltage status information by referencing the column Description, for example.
Options
You can set up specific settings for Scenes in the Options.
Learn more »RDM
Customization
Preset
Shows or hides the Preset column.
Fade-In Time
Shows or hides the Fade-In Time column.
Fade-Out Time
Shows or hides the Fade-Out Time column.
Wait Time
Shows or hides the Wait Time column.
Programming State
Shows or hides the Programming State column.
Resize All Columns To Content
