▪Important Notes
▪Using The MADRIX USB Flash Drive
▪Downloading The Software Online
▪Setup Process
▪Uninstallation
▪Software Update
Important Information
▪Please note regarding Purchased Products, Demo Mode, and Updates:
- The MADRIX RADAR Software can be downloaded from »www.madrix.com. Software updates will be also released online.
- If no license is unlocked, the software will run in demo mode. Learn more »License System
▪It is highly recommended to always use the latest software update.
When using a MADRIX USB flash drive for the installation process, please connect the drive to a free USB port of your operational computer. The MADRIX RADAR setup will start automatically using an Auto Installer. Please wait until the setup has fully loaded. Then, proceed with the Setup Process as described below. When the Auto Installer does not launch, please navigate to the drive in Windows and manually start the setup process by performing a double-click on MADRIX_RADAR_Install.exe
▪Download MADRIX_RADAR_Install.exe from »www.madrix.com
▪After downloading the installer, please double-click with your mouse on this file in order to start the setup process.
▪ Please wait while the Auto Installer is loading the setup.
▪Afterwards, proceed with the Setup Process as described below.
Setup Process
Please make sure to:
1] Log into Windows as administrator [Admin].
2] Let the computer process the setup. This may take some minutes depending on the speed of your computer.
3] Allow Windows to install all drivers. Windows may ask for your permission to install drivers and expects your confirmation. Please search for such pop-up windows; they might have opened in the background and might be covered by other windows.
4] If available, connect your MADRIX KEY before you start a software update [not during the first installation]. In this way, the MADRIX KEY firmware can automatically be updated if required.
Please install the MADRIX RADAR Software before you connect a MADRIX KEY.
Step 1]
▪Please select your preferred language and confirm with OK
▪You can always quit the setup by clicking Cancel |
Step 2]
▪Click Next to start the installation.
▪Click Back in order to return to a previous step during the setup process. |
Step 3]
▪The License Agreement will appear. It outlines the terms you are agreeing to by installing the software. You must accept these terms in order to continue.
▪Please click I Agree |
Step 4]
▪This window allows you to select which components and which drivers you want to install. A description is given for each item.
▪MADRIX RADAR - Is a required component. It refers to the MADRIX RADAR Software.
▪Desktop Shortcut - Select if you wish to create a shortcut to the software on your Windows desktop. By default, the component is selected.
▪Quick Launch Shortcut - Select if you wish to create a shortcut to the software in your Windows taskbar. By default, the component is not selected.
▪MADRIX KEY Driver - Is a required component. Installs the MADRIX KEY driver.
▪MADRIX KEY Firmware Update - Select if you wish to install the latest firmware on connected USB protection dongles. Please disconnect any unwanted dongles if you select the option.
▪Next - Click Next after choosing the components in order to continue. |
Step 5]
▪Choose an installation directory on your hard drive where the software will be installed. A default Destination Folder will automatically be provided by the setup.
▪Browse... - Click to change the folder.
▪Install - Click to start the installation process. |
Step 6]
▪The installation process may take a few minutes.
▪Installation Complete - Click Next when this message shown. |
Step 7]
▪Run MADRIX RADAR - Deselect if you do not wish to start the software now.
▪Finish - Click to quit the setup.
▪When starting MADRIX RADAR for the first time, please make sure to learn more about working with Windows.
Learn more »Tips [Microsoft Windows / Networks / USB] |
Uninstallation
Step 1]
▪You can always quit the uninstaller by choosing Cancel
▪Click Back in order to return to a previous step during the process. |
Step 1]
▪Click Next to start the uninstallation. |
Step 2]
▪This window allows you to select which components and which drivers you want to uninstall. A description is given for each item.
▪Log Files - Select if you wish to remove all files saved for logging. By default, the component is selected.
▪Documents - Select if you wish to remove the Documents folder specific to this software from the My Documents directory; except log files. By default, the component is not selected.
▪MADRIX KEY Driver - Select if you wish to uninstall the drivers of the MADRIX KEY. By default, the component is not selected.
[Only remove it if no other software, such as MADRIX 5, requires the driver. If you have such software installed and are using it, do not remove the driver.]
▪Uninstall - Click Uninstall after choosing the components in order to continue. |
Step 3]
▪The uninstallation process may take a short while.
▪Uninstallation Complete - Click Close when this message shown. |
Software Update
Checking For New Software Versions
It is always recommended to run the latest software version. MADRIX RADAR automatically searches for updates at startup.
▪By default, the option is enabled. To change it, select the menu Preferences > Options... > Startup > Check For Software Updates
▪Choose Skip This Version if you would like to skip a particular version.
Installing New Software Versions
When a new software version has been released, please update your current MADRIX RADAR installation to the newest version.
▪Check and download the latest MADRIX RADAR Software as described above.
▪You can also directly download it from »www.madrix.com
▪It is not required to deinstall MADRIX RADAR before you install a new software version.
▪Instead, follow the process described under Downloading The Software Online
▪The installer will ask you if you would like to update your current MADRIX RADAR Software installation. Confirm with Yes
