NewTek NDI |
Based on the widely available IP technology, NDI [abbr., Network Device Interface] by NewTek makes streaming video over standard network easily possible.
▪With MADRIX 5, you can send or receive video or the software's output stream over NDI. ▪The features are directly built into the software without the need for any additional drivers. ▪NDI is usually used between two or more separate devices. ▪NDI version 5.5.3 is currently supported. ▪Any other sender or receiver also needs to support NDI. Otherwise, the connection will not work. ▪Make sure that all senders and receivers of NDI are connected to the same Ethernet computer network.
Step-By-Step Configuration 1] Prerequisites. 2] Patching DVI fixtures. 3] Adding an NDI DVI Device. 4] Important information.
1] Prerequisites ▪The NDI network settings are automatically set up for you. ▪You only need a computer with a network card and a valid IP address. ▪You do not have to change the IP address settings in Windows for NDI! ▪You need to patch DVI fixtures [see below].
2] Patching DVI Fixtures ▪Configure your LED matrix first. ▪You need to add DVI fixtures [Fixture Protocol > DVI]. Otherwise, it will not work and no output is sent. ▪ Learn more »Matrix Generator or »Patch Editor
3] Activating The DVI Device ▪Go to the menu Preferences > Device Manager... > DVI Devices
▪Add devices manually. ▪The new DVI device will appear in the list after is has been added.
There are different Settings available for further configuration. By default, all settings should be set up correctly already. ▪If you change a setting, always click Apply to confirm the changes. ▪Enable - Activates or deactivates the currently selected DVI device. This is activated by default. It needs to be activated in order to work correctly. ▪Use Full Size - Displays the full Matrix Size on the device. This is activated by default and the recommended setting. Scaling is not available.
▪Set Frame Time - Activate in order to set a different frame time in milliseconds. By default, the DVI device is set to be an Event type with the software's main mixing frame rate [50 FPS by default] .
▪ - Removes the currently selected DVI devices. ▪ - Makes your device flash and will set all pixels instantly to white for testing purposes.
4] Important Information ▪The MADRIX 5 Software does not send an Alpha channel. ▪The MADRIX 5 Software does not send or receive audio over NDI. ▪NDI uses video compression in order to manage the amount of video data that is sent over Ethernet network.
In order to receive NDI, you need to use the MADRIX Effect SCE Capture
Step-By-Step Configuration 1] Prerequisites. 2] Using SCE Capture.
1] Prerequisites ▪Make sure that you are sending NDI over network. ▪The NDI network settings are automatically set up for you. ▪You only need a computer with a network card and a valid IP address. ▪You do not have to change the IP address settings in Windows for NDI!
2] Using SCE Capture ▪Select SCE Capture from the library of effects.
▪ - Open a device.
▪Select your NDI sender from the list.
▪MADRIX 5 will now receive NDI over Network.
▪Learn more »SCE Capture
Newtek provides the following information: ▪"npcap loopback adapter has been found to interfere with NDI operation and performance. This driver is not required or used by modern versions of Wireshark. If you find this is installed on your system, then is installed recommend that you go to your network settings and use the context menu on the adapter to disable it." ▪"NDI now uses predictable port numbers in all cases so that fire-wall rules can be properly built."
MADRIX 5.6. |
