MREC Conversion |
You can use the Recording functionality to create MADRIX 5 Record files [of the file type *.mrec] as described in the previous chapter »Recording In order to make use of the advantages of the *.mrec file format, you can convert video files into MREC files.
Some of the advantages are: ▪Always full compatibility with the MADRIX 5 Software without the need for a separate video codec. ▪Full compatibility with all playback modes Once, Loop, and Bounce ▪Full compatibility with Step 1 Frame Back and Skip 1 Frame ▪Full compatibility with single-frame scrubbing [frame by frame].
Overview ▪Go to the menu Tools > Record Editing... ▪A new window will open. ▪Go to MREC Conversion
Step-By-Step Instructions 1] Load the video file. 2] Define the destination. 3] Start the export process.
1] Loading The Video File - Please note: You can load any video that the Media Foundation decoder is able to load. A large variety of file formats and video codecs is supported, but compatibility with all formats/codecs cannot be guaranteed.
2] Defining The Destination File
Destination File - Define the output video file. This will be the final file. Resolution - The pixel resolution in X and Y of the video. FPS - The frames per second of the video. Codec - The video codec the file is encoded with.
3] Exporting The MREC File
Export - Starts the export process.
Follow these steps to finally play back the record file in SCE Video: 1] Select the effect SCE Video.
2] The controls of the SCE Video effect become available as a result.
3] Load your MADRIX 5 Record file [of the file type *.mrec].
4] The SCE Video effect will play your file.
MADRIX 5.6. |
