Audio And Sound |
This topic includes: ▪Audio Configuration In The Windows Operating System ▪Audio Configuration In The MADRIX 5 Software
MADRIX 5 supports audio input as well as audio output. ▪Audio input is used for a variety of MADRIX Effects and therefore audio-reactive visuals. The software uses incoming audio signals to create lighting effects. These include the S2L, M2L, and MAS Effects. ▪Audio output is used as audio playback for video files in the SCE Video Effect. MADRIX 5 can work with an audio signal and it can work without an audio signal. But audio input is highly recommended. S2L and M2L Effects will create unique real-time effects based on sound, which will take your lighting display to the next level.
Audio input can come from different sources [internal or external]. It is just a matter of configuration. MADRIX 5 will allow you to set up every device that the Microsoft Windows operating system offers for recording. Internal sources: ▪Software MP3 players [including other audio file types or music tracks] ▪Other music or audio applications ▪Microphone [e.g., built into notebooks] ▪Audio-CD ▪Stereo Mix ▪Others External sources: ▪Line-In ▪Microphone ▪SPDIF ▪Others
Audio output can only come from videos played back in the SCE Video Effect. [The MADRIX 5 Software is primarily a lighting control tool without advanced audio functions.]
If MADRIX 5 should use an audio input or audio output signal, you have to define the proper audio device in Windows first.
The Recording device is used for audio input.
The Playback device is used for audio output.
Make also sure to set the right settings for the Windows Volume Mixer.
Audio Configuration In The MADRIX 5 Software ▪Audio Input Configuration With WDM ▪Audio Input Configuration With ASIO
▪Go to the menu Preferences > Device Manager... > Audio
Audio Input Configuration With WDM ▪Enable Audio Input - Enables the standard Windows audio drivers [Windows Driver Model]. It is activated by default. ▪Audio Device - Shows all available audio input sources. ▪Use For S2L Effects - Is activated by default. Deactivate this option if incoming audio signals should not be used for MADRIX 5 S2L Effects [not recommended]. ▪Use For M2L Effects - Is activated by default. Deactivate this option if incoming audio signals should not be used for MADRIX 5 M2L Effects [not recommended].
Audio Input Configuration With ASIO ASIO [Audio Stream Input/Output] is a widely known audio standard. ASIO is a trademark and software of Steinberg Media Technologies GmbH.
▪Before using ASIO with MADRIX 5, please make sure that the ASIO drivers are installed on your computer. If the drivers are not installed, MADRIX 5 will not be able to find the ASIO audio hardware. ▪It is recommended to connect external ASIO hardware [a USB sound card, for example] directly to a USB controller of your PC. It is not recommended to use a USB hub or the front-USB of your computer. ▪Use USB 2.0.
▪Enable Audio Input - Enables the ASIO audio drivers. Configure the following settings: ▪Audio Device - Select your interface or sound card in this drop-down list. ▪Left Channel - Select the appropriate device for the left audio channel. ▪Right Channel - Select the appropriate device for the right audio channel. ▪Use For S2L Effects - Is activated by default. Deactivate this option if incoming audio signals should not be used for MADRIX 5 S2L Effects [not recommended]. ▪Use For M2L Effects - Is activated by default. Deactivate this option if incoming audio signals should not be used for MADRIX 5 M2L Effects [not recommended].
Will let you configure your ASIO device further if advanced settings are available. Usually, the ASIO drivers that come with your interface will be launched. Make sure that your ASIO hardware is connected. Or else, no configuration window may be launched. ▪In this configuration window you can set various settings. The music analysis will be more precise if the latency / amount of samples is as low as possible. Often, this setting is called 'Buffersize'. You can achieve milliseconds with ASIO. 1000 frames represent 1 ms. 500 frames represent 2 ms. 250 frames represent 4 ms, and so on. You will be able to see the number of frames that is captured in the Task Watcher. ▪Click Apply to save the settings.
▪Enable Audio Output
▪Audio Device - Shows all available audio output devices.
The results of the audio analysis are mainly influenced by the following factors: ▪Computer speed. ▪Level of the audio signal. ▪Audio Performance settings.
You are able to adjust Audio Performance settings, which are the parameters for the audio analysis. ▪Go to the menu Preferences > Audio Performance... ▪A new window will open.
▪S2L M2L Performance - Defines how much data is available for the audio analysis. The default value is 3. ▪M2L Cleaner - Works only for M2L Effects and harmonic frequencies. It cleans the incoming audio signal for resonances and secondary frequencies to filter out unwanted tones. ▪M2L Threshold - Works only for M2L Effects and defines a threshold value. ▪Defaults - Restores the default settings. ▪OK - Applies any changes and closes the window. ▪Apply - Applies any changes without closing the window. [In this way, this allows you to quickly test different settings. Change the settings, click Apply, and observe the results for S2L and M2L Effects.] ▪Cancel - Disregards any changes and closes the window.
Different styles of music may require different Audio Performance settings for an optimal display.
The volume or audio input level as well as audio output level can be controlled on the user interface. ▪Learn more »Main Output / Master / Audio Levels ▪Learn more »SCE Video
If you are having problems with the audio configuration, try the following: ▪Select Preferences > Device Manager... > Audio > Defaults to restore the default settings. Alternatively, select the correct audio device [e.g., Stereo Mix]. ▪Check the Windows audio settings and see if your recording or playback devices are configured correctly. ▪Check that the Windows Volume Mixer has the right sound levels and is not set to 0. ▪Check the installation of the [latest] drivers of your sound card. ▪Check the installation of Microsoft DirectX®. ▪Test with a different sound card. ▪If you are encountering problems with ASIO [when effects freeze or single frequencies overmodulate], change the latency settings. A higher latency and thus lower capture frame rates can solve the problem. ▪You may need to grant permission in the Windows operating system and its Privacy settings to use the microphone. ▪Make sure that MADRIX 5 is allowed to take control of the audio device. In Windows 10, go to Start > Windows System > Control Panel > Sound > Recording > Right-Mouse Click on the device > Properties > Advanced and deactivate Allow applications to take exclusive control of this device
MADRIX 5.6. |
