SCE Clouds
SCE Clouds creates random, organic visuals that are reminiscent of clouds.
Colors - Opens the Color Gradient to specify the colors. The default color is White, Black.
Frequency - Defines the rate at which new, organic visuals are created [in Hz]. The default value is 10. Valid values range from 0 to 50.
Stretch - Defines the stretch or compression factor at which the visuals are displayed [X, Y, Z]. The default values are 1, 1, 1. Valid values range from 0.01 to 1000.
Contrast - Defines the visual differentiation of colors and shapes [in %]. The default value is 50. Valid values range from 1 to 1000.
Detail - Defines the sharpness [in %]. The higher the Detail, the more computer performance is required. The default value is 2. Valid values range from 1 to 10.
Distinction - Defines the cohesiveness of the effect [in %]. The default value is 50. Valid values range from 1 to 100.
Generate - Creates the effect anew to produce different visuals. [This is mainly useful when setting a Frequency of 0.]
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default value is None. Learn more »Using Directions
Display Mode - Allows you to choose how the effect mainly looks [Low Contrast, Medium Contrast, High Contrast, Outline, Cluster]. The default mode is Low Contrast.
MADRIX 3.6i
