DMX-IN [General Protocol]
Other Protocols
The General protocol is a pre-configured DMX protocol [or profile] you can use for Remote Control.
General Protocol uses 26 DMX channels.
It includes the Simple Protocol.
Valid incoming DMX values are 0 - 255.
DMX Channel
Remote Control Function
DMX Values
Functionality
Comment
01
Storage Left Storage ID
0 - 255
Storage, Left, 1 - 256
Choose Storage 1 to 256 on the Left side.
02
Storage Left Place +Fade
0 - 255
Storage Place, Left, 1 - 256
Choose your Storage Place in the selected Storage on the Left side. A fade of the crossfader is applied automatically according to the Fade Time.
03
Fade Time In 1/10 Seconds
0 - 255
Fade Time, 0 - 10s
0 = 0s
127 = 5s
255 = 10s
Steps of 2 or 3 = 0.1s
Set up the Fade Time of the Crossfader in tenths of a second.
04
Global Master
0 - 255
0 - 255
Control the overall intensity.
05
Global Blackout
0   - 127
128 - 255
= Off
= On
Activate or deactivate the overall Blackout.
06
Fade Type
0 - 15
0  = XF
1  = WF
2  = BF
3  = CF
4  = Wipe X
5  = Wipe Y
6  = Wipe XC
7  = Wipe YC
8  = Slide X
9  = Slide Y
10 = Slide XC
11 = Slide YC
12 = Wipe Z
13 = Wipe ZC
14 = Slide Z
15 = Slide ZC
Set up the Fade Type of the crossfader.
07
Fade Color Red
0 - 255
Color value, 0 - 255
Set up the red color values for the Color Fade.
08
Fade Color Green
0 - 255
Set up the green color values for the Color Fade.
09
Fade Color Blue
0 - 255
Set up the blue color values for the Color Fade.
10
Fade Color White
0 - 255
Set up the white color values for the Color Fade.
11
Global Filter Red
0 - 255
0 - 255
Set up the red color values for the Main Output Color Filter.
12
Global Filter Green
0 - 255
0 - 255
Set up the green color values for the Main Output Color Filter.
13
Global Filter Blue
0 - 255
0 - 255
Set up the blue color values for the Main Output Color Filter.
14
Global Filter White
0 - 255
0 - 255
Set up the white color values for the Main Output Color Filter.
15
Global Output Freeze
0   - 127
128 - 255
= Off
= On
Activate or deactivate the overall Main Output Freeze.
16
Audio Input Level
0 - 255
0 - 255
Control the maximum audio input level.
17
Audio Automatic Gain Control
0   - 127
128 - 255
= Off
= On
Activate or deactivate the Audio Gain Control.
18
Global Output Strobe
0   - 127
128 - 255
= Off
= On
Activate or deactivate the Main Output Strobe.
19
Global Output Strobe Color Red
0 - 255
Set up the red color values for the Main Output Strobe.
20
Global Output Strobe Color Green
0 - 255
Set up the green color values for the Main Output Strobe.
21
Global Output Strobe Color Blue
0 - 255
Set up the blue color values for the Main Output Strobe.
22
Global Output Strobe Color White
0 - 255
Set up the white color values for the Main Output Strobe.
23
Cue List Play / Pause Toggle
0   - 127
128 - 255
= Off
= On
Start or halt the Cue List.
24
Cue List Go
0   - 127
128 - 255
= Off
= On
Skip to the next Cue List entry.
25
Cue List Back
0   - 127
128 - 255
= Off
= On
Go back to the previous Cue List entry.
26
Cue List Goto
0 - 255
Cue, 1 - 256
Directly skip to the corresponding Cue List entry.
Other Protocols
There are other preprogrammed DMX protocols you can choose from:
»DMX-IN [Simple Protocol]
»DMX-IN [General Protocol]
»DMX-IN [Advanced Protocol]
»DMX-IN [User]
