DMX Channel
Remote Control Function
DMX Values
Functionality
Comment
01
Storage Left Storage ID
0 - 255
Storage, Left, 1 - 256
Choose Storage 1 to 256 on the Left side.
02
Storage Left Place +Fade
0 - 255
Storage Place, Left, 1 - 256
Choose your Storage Place in the selected Storage on the Left side. A fade of the crossfader is applied automatically according to the Fade Time.
03
Fade Time In 1/10 Seconds
0 - 255
Fade Time, 0 - 10s
0 = 0s
127 = 5s
255 = 10s
Steps of 2 or 3 = 0.1s
Set up the Fade Time of the crossfader in tenths of a second.
04
Global Master
0 - 255
0 - 255
Control the overall intensity.
05
Global Blackout
0 - 127
128 - 255
= Off
= On
Activate or deactivate the overall Blackout.
06
Fade Type
0 - 15
0 = XF
1 = WF
2 = BF
3 = CF
4 = Wipe X
5 = Wipe Y
6 = Wipe XC
7 = Wipe YC
8 = Slide X
9 = Slide Y
10 = Slide XC
11 = Slide YC
12 = Wipe Z
13 = Wipe ZC
14 = Slide Z
15 = Slide ZC
Set up the Fade Type of the crossfader.
07
Fade Color Red
0 - 255
Color value, 0 - 255
Set up the red color values for the Color Fade.
08
Fade Color Green
0 - 255
Set up the green color values for the Color Fade.
09
Fade Color Blue
0 - 255
Set up the blue color values for the Color Fade.
10
Fade Color White
0 - 255
Set up the white color values for the Color Fade.
11
Global Filter Red
0 - 255
0 - 255
Set up the red color values for the Main Output Color Filter.
12
Global Filter Green
0 - 255
0 - 255
Set up the green color values for the Main Output Color Filter.
13
Global Filter Blue
0 - 255
0 - 255
Set up the blue color values for the Main Output Color Filter.
14
Global Filter White
0 - 255
0 - 255
Set up the white color values for the Main Output Color Filter.
15
Global Output Freeze
0 - 127
128 - 255
= Off
= On
Activate or deactivate the overall Main Output Freeze.
16
Audio Input Level
0 - 255
0 - 255
Control the maximum audio input level.
17
Audio Automatic Gain Control
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Audio Gain Control.
18
Global Output Strobe
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Main Output Strobe.
19
Global Output Strobe Color Red
0 - 255
Set up the red color values for the Main Output Strobe.
20
Global Output Strobe Color Green
0 - 255
Set up the green color values for the Main Output Strobe.
21
Global Output Strobe Color Blue
0 - 255
Set up the blue color values for the Main Output Strobe.
22
Global Output Strobe Color White
0 - 255
Set up the white color values for the Main Output Strobe.
23
Cue List Play / Pause Toggle
0 - 127
128 - 255
= Off
= On
Start or halt the Cue List.
24
Cue List Go
0 - 127
128 - 255
= Off
= On
Skip to the next Cue List entry.
25
Cue List Back
0 - 127
128 - 255
= Off
= On
Go back to the previous Cue List entry.
26
Cue List Goto
0 - 255
Cue, 1 - 256
Directly skip to the corresponding Cue List entry.
27
Storage Right Storage ID
0 - 255
Storage, Right, 1 - 256
Choose Storage 1 to 256 on the Right side.
28
Storage Right Place +Fade
0 - 255
Storage Place, Right, 1 - 256
Choose your Storage Place in the selected Storage on the Rights side. A fade of the crossfader is applied automatically according to the Fade Time.
29
Storage Left Place
0 - 255
30
Storage Right Place
0 - 255
Choose your Storage Place in the selected Storage on the Right side.
31
Storage Left Submaster
0 - 255
Storage Submaster, Left, 0 - 255
Control the Storage Submaster on the Left side.
32
Storage Right Submaster
0 - 255
Storage Submaster, Right, 0 - 255
Control the Storage Submaster on the Right side.
33
Storage Left Speed
0 - 255
Speedmaster, Left, -10 to 10
0 = -10
127 = 0.0
255 = 10
Steps of 1 or 2 = 0.1
Control the overall Speedmaster on the Left side.
34
Storage Right Speed
0 - 255
0 = -10
127 = 0.0
255 = 10
Control the overall Speedmaster on the Right side.
35
Storage Left Speed Pause
0 - 127
128 - 255
= Off
= On
Activate or deactivate the overall Pause function of the Speedmaster Left.
36
Storage Right Speed Pause
0 - 127
128 - 255
= Off
= On
Activate or deactivate the overall Pause function of the Speedmaster Right.
37
Fade Value
0 - 255
Crossfader, Left to Right
0 = Left
127 = 50%, middle position
255 = Right
Control the Crossfader.
38
Fade Automatic
0 - 127
128 - 255
= Off
= On
Trigger an automatic fade of the Crossfader.
39
Fade Value
0 - 254
Crossfader, Skip Left
0 -254 = Left
Directly skip the Crossfader to the Left.
40
Fade Value
1 - 255
Crossfader, Skip Right
255 = Right
Directly skip the Crossfader to the Right.
41
Layer Left Layer
0 - 255
Layer, Left
0 = Layer 1
1 = Layer 2
2 = Layer 3
3 = Layer 4
etc.
Select the corresponding Layer on the Left side.
42
Layer Right Layer
0 - 255
Layer, Right
0 = Layer 1
1 = Layer 2
2 = Layer 3
3 = Layer 4
etc.
Select the corresponding Layer on the Right side.
43
Layer Left Opacity Current Layer
0 - 255
0 - 255
Control the Opacity of the currently selected Layer on the Left side.
44
Layer Left Opacity Layer 1
0 - 255
0 - 255
Control the Opacity of Layer 1 on the Left side.
45
Layer Left Opacity Layer 2
0 - 255
0 - 255
Control the Opacity of Layer 2 on the Left side.
46
Layer Left Opacity Layer 3
0 - 255
0 - 255
Control the Opacity of Layer 3 on the Left side.
47
Layer Left Opacity Layer 4
0 - 255
0 - 255
Control the Opacity of Layer 4 on the Left side.
48
Layer Left Opacity Layer 5
0 - 255
0 - 255
Control the Opacity of Layer 5 on the Left side.
49
Layer Left Opacity Layer 6
0 - 255
0 - 255
Control the Opacity of Layer 6 on the Left side.
50
Layer Left Opacity Layer 7
0 - 255
0 - 255
Control the Opacity of Layer 7 on the Left side.
51
Layer Left Opacity Layer 8
0 - 255
0 - 255
Control the Opacity of Layer 8 on the Left side.
52
Layer Right Opacity Current Layer
0 - 255
0 - 255
Control the Opacity of the currently selected Layer on the Right side.
53
Layer Right Opacity Layer 1
0 - 255
0 - 255
Control the Opacity of Layer 1 on the Right side.
54
Layer Right Opacity Layer 2
0 - 255
0 - 255
Control the Opacity of Layer 2 on the Right side.
55
Layer Right Opacity Layer 3
0 - 255
0 - 255
Control the Opacity of Layer 3 on the Right side.
56
Layer Right Opacity Layer 4
0 - 255
0 - 255
Control the Opacity of Layer 4 on the Right side.
57
Layer Right Opacity Layer 5
0 - 255
0 - 255
Control the Opacity of Layer 5 on the Right side.
58
Layer Right Opacity Layer 6
0 - 255
0 - 255
Control the Opacity of Layer 6 on the Right side.
59
Layer Right Opacity Layer 7
0 - 255
0 - 255
Control the Opacity of Layer 7 on the Right side.
60
Layer Right Opacity Layer 8
0 - 255
0 - 255
Control the Opacity of Layer 8 on the Right side.
61
Layer Left Submaster Current Layer
0 - 255
0 - 255
Control the Submaster of the currently selected Layer on the Left side.
62
Layer Left Submaster Layer 1
0 - 255
0 - 255
Control the Submaster of Layer 1 on the Left side.
63
Layer Left Submaster Layer 2
0 - 255
0 - 255
Control the Submaster of Layer 2 on the Left side.
64
Layer Left Submaster Layer 3
0 - 255
0 - 255
Control the Submaster of Layer 3 on the Left side.
65
Layer Left Submaster Layer 4
0 - 255
0 - 255
Control the Submaster of Layer 4 on the Left side.
66
Layer Left Submaster Layer 5
0 - 255
0 - 255
Control the Submaster of Layer 5 on the Left side.
67
Layer Left Submaster Layer 6
0 - 255
0 - 255
Control the Submaster of Layer 6 on the Left side.
68
Layer Left Submaster Layer 7
0 - 255
0 - 255
Control the Submaster of Layer 7 on the Left side.
69
Layer Left Submaster Layer 8
0 - 255
0 - 255
Control the Submaster of Layer 8 on the Left side.
70
Layer Right Submaster Current Layer
0 - 255
0 - 255
Control the Submaster of the currently selected Layer on the Right side.
71
Layer Right Submaster Layer 1
0 - 255
0 - 255
Control the Submaster of Layer 1 on the Right side.
72
Layer Right Submaster Layer 2
0 - 255
0 - 255
Control the Submaster of Layer 2 on the Right side.
73
Layer Right Submaster Layer 3
0 - 255
0 - 255
Control the Submaster of Layer 3 on the Right side.
74
Layer Right Submaster Layer 4
0 - 255
0 - 255
Control the Submaster of Layer 4 on the Right side.
75
Layer Right Submaster Layer 5
0 - 255
0 - 255
Control the Submaster of Layer 5 on the Right side.
76
Layer Right Submaster Layer 6
0 - 255
0 - 255
Control the Submaster of Layer 6 on the Right side.
77
Layer Right Submaster Layer 7
0 - 255
0 - 255
Control the Submaster of Layer 7 on the Right side.
78
Layer Right Submaster Layer 8
0 - 255
0 - 255
Control the Submaster of Layer 8 on the Right side.
79
Layer Left Mix Mode Current Layer
0 - 23
[Repeats afterwards]
Mix Mode, Left
0 = Normal
1 = Darken
2 = Multiply
3 = Color Burn
4 = Linear Burn
5 = Lighten (HTP)
6 = Screen
7 = Color Dodge
8 = Linear Dodge
9 = Overlay
10 = Soft Light
11 = Hard Light
12 = Vivid Light
13 = Linear Light
14 = Pin Light
15 = Hard Mix
16 = Difference
17 = Exclusion
18 = AND
19 = OR
20 = XOR
21 = NAND
22 = NOR
23 = Mask
Set up one out of 24 mix modes for the currently selected Layer on the Left side.
80
Layer Left Mix Mode Layer 1
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 1 on the Left side.
81
Layer Left Mix Mode Layer 2
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 2 on the Left side.
82
Layer Left Mix Mode Layer 3
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 3 on the Left side.
83
Layer Left Mix Mode Layer 4
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 4 on the Left side.
84
Layer Left Mix Mode Layer 5
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 5 on the Left side.
85
Layer Left Mix Mode Layer 6
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 6 on the Left side.
86
Layer Left Mix Mode Layer 7
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 7 on the Left side.
87
Layer Left Mix Mode Layer 8
0 - 23
Mix Mode, Left
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 8 on the Left side.
88
Layer Right Mix Mode Current Layer
0 - 23
Mix Mode, Right
0 = Normal
1 = Darken
2 = Multiply
3 = Color Burn
4 = Linear Burn
5 = Lighten (HTP)
6 = Screen
7 = Color Dodge
8 = Linear Dodge
9 = Overlay
10 = Soft Light
11 = Hard Light
12 = Vivid Light
13 = Linear Light
14 = Pin Light
15 = Hard Mix
16 = Difference
17 = Exclusion
18 = AND
19 = OR
20 = XOR
21 = NAND
22 = NOR
23 = Mask
Set up one out of 24 mix modes for the currently selected Layer on the Right side.
89
Layer Right Mix Mode Layer 1
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 1 on the Right side.
90
Layer Right Mix Mode Layer 2
0 - 23
Mix Mode, Left
0 = Mix Mode Normal
23 = Mix Mode Mask
Set up one out of 24 mix modes for Layer 2 on the Right side.
91
Layer Right Mix Mode Layer 3
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 3 on the Right side.
92
Layer Right Mix Mode Layer 4
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 4 on the Right side.
93
Layer Right Mix Mode Layer 5
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 5 on the Right side.
94
Layer Right Mix Mode Layer 6
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 6 on the Right side.
95
Layer Right Mix Mode Layer 7
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 7 on the Right side.
96
Layer Right Mix Mode Layer 8
0 - 23
Mix Mode, Right
0 = Normal
23 = Mask
Set up one out of 24 mix modes for Layer 8 on the Right side.
97
Layer Left Blind Current Layer
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for the currently selected Layer on the Left side.
98
Layer Left Blind Layer 1
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 1 on the Left side.
99
Layer Left Blind Layer 2
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 2 on the Left side.
100
Layer Left Blind Layer 3
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 3 on the Left side.
101
Layer Left Blind Layer 4
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 4 on the Left side.
102
Layer Left Blind Layer 5
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 5 on the Left side.
103
Layer Left Blind Layer 6
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 6 on the Left side.
104
Layer Left Blind Layer 7
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 7 on the Left side.
105
Layer Left Blind Layer 8
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 8 on the Left side.
106
Layer Right Blind Current Layer
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for the currently selected Layer on the Right side.
107
Layer Right Blind Layer 1
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 1 on the Right side.
108
Layer Right Blind Layer 2
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 2 on the Right side.
109
Layer Right Blind Layer 3
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 3 on the Right side.
110
Layer Right Blind Layer 4
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 4 on the Right side.
111
Layer Right Blind Layer 5
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 5 on the Right side.
112
Layer Right Blind Layer 6
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 6 on the Right side.
113
Layer Right Blind Layer 7
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 7 on the Right side.
114
Layer Right Blind Layer 8
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Blind Mode for Layer 8 on the Right side.
115
Layer Left Solo Current Layer
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for the currently selected Layer on the Left side.
116
Layer Left Solo Layer 1
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 1 on the Left side.
117
Layer Left Solo Layer 2
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 2 on the Left side.
118
Layer Left Solo Layer 3
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 3 on the Left side.
119
Layer Left Solo Layer 4
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 4 on the Left side.
120
Layer Left Solo Layer 5
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 5 on the Left side.
121
Layer Left Solo Layer 6
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 6 on the Left side.
122
Layer Left Solo Layer 7
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 7 on the Left side.
123
Layer Left Solo Layer 8
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 8 on the Left side.
124
Layer Right Solo Current Layer
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for the currently selected Layer on the Right side.
125
Layer Right Solo Layer 1
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 1 on the Right side.
126
Layer Right Solo Layer 2
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 2 on the Right side.
127
Layer Right Solo Layer 3
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 3 on the Right side.
128
Layer Right Solo Layer 4
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 4 on the Right side.
129
Layer Right Solo Layer 5
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 5 on the Right side.
130
Layer Right Solo Layer 6
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 6 on the Right side.
131
Layer Right Solo Layer 7
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 7 on the Right side.
132
Layer Right Solo Layer 8
0 - 127
128 - 255
= Off
= On
Activate or deactivate the Solo Mode for Layer 8 on the Right side.
133
Layer Left Filter Current Layer
0 - 35
Filter/Effect FX, Right
0 = No FX
1 = Blur
2 = Blur B-Spline
3 = Blur Catmull Rom
4 = Blur Gauss
5 = Blur Mitchell
6 = Sharpen
7 = Brighten
8 = Darken
9 = Grayscale
10 = Invert Color
11 = R
12 = G
13 = B
14 = W
15 = RG
16 = RB
17 = GB
18 = RW
19 = GW
20 = BW
21 = RGB
22 = RGW
23 = RBW
24 = GBW
25 = 6x (Kaleidoscope)
26 = 8x (Kaleidoscope)
27 = 12x (Kaleidoscope)
28 = Edges
29 = Edges Popup
30 = Emboss
31 = Emboss Popup
32 = Mirror H
33 = Mirror V
34 = Mirror HV
35 = Mirror D
36 = Mirror HD
37 = Mirror VD
38 = Mirror HVD
Set up one out of 35 filters for the currently selected Layer on the Left side.
134
Layer Left Filter Layer 1
0 - 35
Filter/Effect FX, Left
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 1 on the Left side.
135
Layer Left Filter Layer 2
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 2 on the Left side.
136
Layer Left Filter Layer 3
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 3 on the Left side.
137
Layer Left Filter Layer 4
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 4 on the Left side.
138
Layer Left Filter Layer 5
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 5 on the Left side.
139
Layer Left Filter Layer 6
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 6 on the Left side.
140
Layer Left Filter Layer 7
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 7 on the Left side.
141
Layer Left Filter Layer 8
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 8 on the Left side.
142
Layer Right Filter Current Layer
0 - 35
0 = No FX
1 = Blur
2 = Blur B-Spline
4 = Blur Gauss
5 = Blur Mitchell
6 = Sharpen
7 = Brighten
8 = Darken
9 = Grayscale
10 = Invert Color
11 = R
12 = G
13 = B
14 = W
15 = RG
16 = RB
17 = GB
18 = RW
19 = GW
20 = BW
21 = RGB
22 = RGW
23 = RBW
24 = GBW
28 = Edges
29 = Edges Popup
30 = Emboss
31 = Emboss Popup
32 = Mirror H
33 = Mirror V
34 = Mirror HV
35 = Mirror D
36 = Mirror HD
37 = Mirror VD
38 = Mirror HVD
Set up one out of 35 filters for the currently selected Layer on the Right side.
143
Layer Right Filter Layer 1
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 1 on the Right side.
144
Layer Right Filter Layer 2
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 2 on the Right side.
145
Layer Right Filter Layer 3
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 3 on the Right side.
146
Layer Right Filter Layer 4
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 4 on the Right side.
147
Layer Right Filter Layer 5
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 5 on the Right side.
148
Layer Right Filter Layer 6
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 6 on the Right side.
149
Layer Right Filter Layer 7
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 7 on the Right side.
150
Layer Right Filter Layer 8
0 - 35
0 = No FX
38 = Mirror HVD
Set up one out of 35 filters for Layer 8 on the Right side.
151
Group Control Value Group 1
0 - 255
0 - 255
Control the (intensity) value of Group 1.
152
Group Control Value Group 2
0 - 255
0 - 255
Control the (intensity) value of Group 2.
153
Group Control Value Group 3
0 - 255
0 - 255
Control the (intensity) value of Group 3.
154
Group Control Value Group 4
0 - 255
0 - 255
Control the (intensity) value of Group 4.
155
Group Control Value Group 5
0 - 255
0 - 255
Control the (intensity) value of Group 5.
156
Group Control Value Group 6
0 - 255
0 - 255
Control the (intensity) value of Group 6.
157
Group Control Value Group 7
0 - 255
0 - 255
Control the (intensity) value of Group 7.
158
Group Control Value Group 8
0 - 255
0 - 255
Control the (intensity) value of Group 8.
159
Group Control Flash Group 1
0 - 127
128 - 255
= Off
= On
Flash the value for Group 1.
160
Group Control Flash Group 2
0 - 127
128 - 255
= Off
= On
Flash the value for Group 2.
161
Group Control Flash Group 3
0 - 127
128 - 255
= Off
= On
Flash the value for Group 3.
162
Group Control Flash Group 4
0 - 127
128 - 255
= Off
= On
Flash the value for Group 4.
163
Group Control Flash Group 5
0 - 127
128 - 255
= Off
= On
Flash the value for Group 5.
164
Group Control Flash Group 6
0 - 127
128 - 255
= Off
= On
Flash the value for Group 6.
165
Group Control Flash Group 7
0 - 127
128 - 255
= Off
= On
Flash the value for Group 7.
166
Group Control Flash Group 8
0 - 127
128 - 255
= Off
= On
Flash the value for Group 8.
167
Group Control Value Default Group All
0 - 127
128 - 255
= Off
= On
Restore the default (intensity) values of all Groups.
