Group Control Using Group Value Chaser |
This tutorial shows you how to use the Group Value Chaser in MADRIX 5.
Date: 06/2021 Corresponding Video Tutorial: »Using the Group Value Chaser
Note: In this tutorial we will work with the result of the tutorial »Layer Mapping With Fixture Groups.
Task: The Group Value Chaser should fade the dimmer values between 0 and 255 in a kind of even odd mode. Furthermore the Fade Type of the Chaser steps should be changed from Linear to Ease Out Bounce, the Fade Time set to 2 seconds and the Wait Time to 0 seconds.
Congratulations! You have successfully learned how to work with the Group Value Chaser in MADRIX 5.
| MADRIX 5 Tutorials Version 1.0 |
