Device List
Device List
List Of Available Art-Net Devices
MADRIX STELLA 8 uses standard mechanics of the Art-Net protocol to find available Art-Net devices in the network.
Search - Searches for Art-Net devices in the network. [Please allow a few seconds for devices to appear in the list.]
Remove - Removes all Art-Net devices from the list.
2 Of 2
[X Available Of Y Found]
Shows the number of Art-Net devices that are available and the number that has been found.
Sort By
Allows you to sort the list alphabetically by Type, IP Address, State, or Firmware Version.
An index number of the Art-Net devices is provided for easier referencing.
Type
Shows if the device could be identified further:
▪Art-Net [For any generic Art-Net device that is not MADRIX software or a MADRIX hardware controller.]
▪MADRIX [For MADRIX 5 Software.]
▪MadrixTimeCodeSender [For MADRIX 5 Time Code Sender Software.]
▪RADAR [For MADRIX RADAR Software.]
▪PLEXUS [For MADRIX PLEXUS devices.]
▪LUNA 4 [For MADRIX LUNA 4 devices.]
▪LUNA 8 [For MADRIX LUNA 8 devices.]
▪LUNA 16 [For MADRIX LUNA 16 devices.]
▪NEBULA [For MADRIX NEBULA devices.]
▪STELLA [For MADRIX STELLA devices.]
▪ORION [For MADRIX LUNA 8 devices.]
▪AURA [For MADRIX AURA devices.]
▪STELLA 8 [For other MADRIX STELLA 8 devices.]
IP Address
Shows the IP address of the Art-Net device.
If shown underlined in blue, it can be used as a click-able link to call up the Art-Net device with this IP address in the web browser.
OEM ID
Shows the OEM ID the Art-Net device has reported.
ESTA ID
Shows the ESTA ID the Art-Net device has reported.
State
Shows the status of the Art-Net device.
▪Timeout [The connection to this device has timed out.]
▪Available [The connection to the device is active.]
Firmware Version
Shows the firmware version of the Art-Net device, if available.
Locate
Mute
Normal
Locate
Allows you to use the ArtAddress commands:
▪Mute Status Indicators - Switches off and disables all built-in status indicators of a device over Art-Net [ArtAddress > AcLedMute].
▪Operate Status Indicators Normally - Allows the built-in status indicators of a device to operate normally again, after having them switched off [ArtAddress > AcLedNormal].
▪Locate Device - Activates the highlight mode [ArtAddress > AcLedLocate]. The corresponding status indicators of the selected interfaces will flash for a better identification or tests.
This makes it easier to see the device on site/stage. It considerably speeds up the procedure of programming or testing the selected interfaces.
