Input [USB]
You Are Here:  Using MADRIX 5 Software >
Input [USB]
DMX-IN Via USB
You can connect the STELLA directly via USB to the computer that runs the MADRIX 5 Software. Data is sent to the STELLA via a port and from the STELLA to MADRIX 5 via USB.
1] Initial Configuration
▪Connect your external DMX controller to the required DMX port of MADRIX STELLA.
▪Connect MADRIX STELLA to your computer via USB.
[Use the provided USB cable]
▪Make sure to check the power-management options of Windows. Learn more »PC Power Management
2] Enabling Drivers In MADRIX 5
▪Go to the menu Preferences > Options... > Devices USB
▪Activate MADRIX STELLA
[The option is activated by default.]
▪Click Apply
▪Close the window with OK
Devices (USB/PCI)
3] Activating Devices
[Keyboard shortcut: F4]
▪Your STELLA devices and their two ports will appear in the list.
▪If your devices are not in the list, click
[In the screenshot below, one STELLA is connected.]
▪Select the required port in the list.
▪Right Mouse Click on the column OUT / IN to set to IN for data input.
▪If required, change the frame time.
  Please note: If you want to output high frame rates, make sure to set Main Mixing FPS in the Options to the same value in order to render the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
  Please note: If you want to input high frame rates, make sure to set DMX Controller Input FPS in the Options to the same value in order to process the same frame rate [It is set to 50 FPS by default. Otherwise, frames will be duplicated].
4] Activating DMX Input
▪Go to the menu Preferences > Device Manager... > DMX Input
DMX Input Tab
▪Select your preferred DMX Universe in the list.
[By default, DMX universe 1 to 8 are listed. If you wish to increase the number of DMX-IN universes, you can change the setting under menu Preferences > Options... > Performance]
▪Choose your DMX-IN Device in the section Device. Select MADRIX STELLA
▪DMX-IN is now activated. MADRIX 5 can already receive DMX data.
▪Now, choose how to use incoming data as explained below.
5] DMX-IN
Data
▪At this point, MADRIX 5 is now already receiving any incoming data.
▪You can now use this data, for example for Scripts and Macros.
▪If you want to monitor incoming signals, select your DMX universe/DMX device in the list and click
Mapping
▪Use Mapping, if you want to route incoming DMX signals through MADRIX 5 to your output [DMX-Thru].
▪First, select your device in the list.
▪Activate Mapping
▪This feature maps incoming data to the specified DMX universe and channels.
Mapping
▪Configure the following settings in the section Mapping
- Map Channels From - Defines which incoming channels are used. This is the start channel to specify the range of channels.
- To - Defines which incoming channels are used. This is the end channel to specify the range of channels.
- To Universe - Defines onto which output DMX universe MADRIX 5 should map the specified range of incoming channels.
- Start At Channel - Defines the first DMX channel of the output DMX universe MADRIX 5 should use.
- Use HTP - Activates the Highest Takes Precedence feature. You can map incoming data to a DMX address range that MADRIX 5 already controls. Use HTP and MADRIX 5 will compare incoming values with the DMX data it sends to the DMX output. As a result, MADRIX 5 will only use the highest of both values on a particular channel and send it to the output.
▪Click Apply to confirm.
Remote Control
▪Use Remote Control, if you want to control the MADRIX 5 Software remotely
▪Activate Remote
▪Select one of the built-in protocols in the section Remote Control as explained below
or create your own remote configuration.
Mapping
Open MADRIX MIDI Remote Configuration
Open - Loads a previously saved MADRIX 5 DMX Remote Configuration file [of the file type *.mdrx].
DMX-IN Protocols
Protocols - Choose from a pre-configured protocol [configuration].
MIDI Remote Control Edit
DMX-IN Remote Editor - Allows you to modify a configuration or create a new configuration.
Start Address
Start Address - Defines on which particular DMX channel the protocol should start. The whole protocol will be mapped to this new address area.
DMX Watcher - Opens the DMX Watcher to monitor your DMX output or input.
Trigger
▪Use Trigger, if you want to use incoming signals for the MADRIX 5 TRI Effects.
▪Activate Trigger
Mapping
Port - Defines the port [Port 1 - 8] that is assigned to this DMX-IN Device. MADRIX 5 allows you to send trigger signals from up to 8 different devices [8 ports] and assign a MADRIX 5 TRI Effect the corresponding port.
Value Range - Defines the range of incoming DMX values that can be used as trigger signal.
- The minimum and default value is 1.
- The maximum and default value is 512.
Assign Minimum Value - Automatically assigns the minimum value when using the controller.
- Click Assign and use the control on your controller for the minimum value and the value will be set automatically in the MADRIX 5 Software.
Assign Maximum Value - Automatically assigns the maximum value when using the controller.
- Click Assign and use the control on your controller for the maximum value and the value will be set automatically in the MADRIX 5 Software.
