MADRIX STELLA 8
You Are Here:  MADRIX RDM Nodes >
MADRIX STELLA 8
MADRIX STELLA 8 is the 8-port flagship controller with RDM support for ultimate control over DMX.
MADRIX STELLA 8 combines incredible features for DMX512 and RDM into a single DIN-rail controller that easily copes with high bandwidths in data-intensive lighting-control networks.
RDM Role: A) Transmits commands and requests to RDM Responders and back (Art-Net Node / RDM Controller), B) Acts on commands and replies to requests with its own status and sensor data via ArtRdm (RDM Responder)
Remote Device Management [RDM]
In order to use it, call up the built-in web configuration [see below] and go to menu Ports and enable RDM for each required port.
Make sure to disable RDM on the specific port, when using STELLA 8 for DMX-IN.
MADRIX RADAR User Manual 1.5.
