Numark Mixtrack Platinum [MIDI Map]
  Previous  Next
Numark Total Control - MIDI Map
Please note: Pad Mode Manual Loop must be activated!
[1] Speed Pitch Storage Place Deck A DOWN
[24] Filter Deck B
[47] Filter Color Red Main Output
[2] Speed Pitch Storage Place Deck A UP
[25] Submaster Deck B
[48] Filter Color Green Main Output
[3] Submaster Deck A
[26 +29 ACTIVATED] Filter Color Red Deck B
[49] Filter Color Blue Main Output
[4 + 6 ACTIVATED] Filter Color Red Deck A
[26 + 30 ACTIVATED] Filter Color Green Deck B
[50] Filter Color White Main Output
[4 + 7 ACTIVATED] Filter Color Green Deck A
[26 + 31 ACTIVATED] Filter Color Blue Deck B
[51] Blackout
[4 + 8 ACTIVATED] Filter Color Blue Deck A
[26 + 32 ACTIVATED] Filter Color White Deck B
[52] Master Value
[4 + 9 ACTIVATED] Filter Color White Deck A
[27] Speed Pitch Storage Place Deck B DOWN
[53] Activate Deck A
[5] Filter Deck A
[28] Speed Pitch Storage Place Deck B UP
[54] Activate Deck B
[10] Speedmaster Deck A
[34 + 33 ACTIVATED] Frame ID Deck B
[55] Storage Place UP DOWN Deck A if [53] is activated
[11 + 12 ACTIVATED] Frame ID Deck A
[34] Speedmaster Deck B
[55] Storage Place UP DOWN Deck B if [54] is activated
[13] Effect Parameter Chaser Deck A Play/Pause Layer 1
[36] Effect Parameter Chaser Deck B Play/Pause Layer 1
[Push 55] Storage UP DOWN Deck A if [53] is activated
[14] Effect Parameter Chaser Deck A Play/Pause Layer 2
[37] Effect Parameter Chaser Deck B Play/Pause Layer 2
[Push 55] Storage UP DOWN Deck B if [54] is activated
[15] Effect Parameter Chaser Deck A Play/Pause Layer 3
[38] Effect Parameter Chaser Deck B Play/Pause Layer 3
[56] Main Output Strobe Activate + Value
[16] Effect Parameter Chaser Deck A Play/Pause Layer 4
[39] Effect Parameter Chaser Deck B Play/Pause Layer 4
[57] Fade Type
[17] Effect Parameter Chaser Deck A Play/Pause Layer 5
[40] Effect Parameter Chaser Deck B Play/Pause Layer 5
[58] Fade Time 1/10 Sec
[18] Effect Parameter Chaser Deck A Play/Pause Layer 6
[41] Effect Parameter Chaser Deck B Play/Pause Layer 6
[59] Main Output Strobe Color Red
[19] Effect Parameter Chaser Deck A Play/Pause Layer 7
[42] Effect Parameter Chaser Deck B Play/Pause Layer 7
[60] Main Output Strobe Color Green
[20] Effect Parameter Chaser Deck A Play/Pause Layer 8
[43] Effect Parameter Chaser Deck A Play/Pause Layer 8
[61] Main Output Strobe Color Blue
[21] Cue List View TOGGLE
[44] Cue List View TOGGLE
[62] Main Output Strobe Color White
[22] Cue Storage Place Deck A
[45] Cue Storage Place Deck B
[63] Audio Input Mute
[23] Cue List Play/Pause TOGGLE
[46] Cue List Play/Pause TOGGLE
[64] Audio Input Value
[65] Crossfader
[66] Output Freeze
MADRIX 5.5.
 Previous   Next
