[1] Speed Pitch Storage Place Deck A DOWN
[24] Submaster Deck B
[47] Filter Color Red Main Output
[2] Speed Pitch Storage Place Deck A UP
[25] Filter Deck B
[48] Filter Color Green Main Output
[3] Submaster Deck A
[26] Speed Pitch Storage Place Deck B DOWN
[49] Filter Color Blue Main Output
[4] Filter Deck A
[27] Speed Pitch Storage Place Deck B UP
[50] Filter Color White Main Output
[4 + 5 PUSH] Filter Color Red Deck A
[25 +28 PUSH] Filter Color Red Deck B
[51] Blackout
[4 + 6 PUSH] Filter Color Green Deck A
[25 + 29 PUSH] Filter Color Green Deck B
[52] Master Value
[4 + 7 PUSH] Filter Color Blue Deck A
[25 + 30 PUSH] Filter Color Blue Deck B
[53] Activate Deck A
[4 + 8 PUSH] Filter Color White Deck A
[25 + 31 PUSH] Filter Color White Deck B
[54] Activate Deck B
[9] Speedmaster Deck A
[33 + 32 ACTIVATED] Frame ID Deck B
[55] Storage Place UP DOWN Deck A if [53] is activated
[10 + 11 ACTIVATED] Frame ID Deck A
[34] Speedmaster Deck B
[55] Storage Place UP DOWN Deck B if [54] is activated
[12] Speedmaster Pause TOGGLE Deck A
[35] Speedmaster Pause TOGGLE Deck B
[Push 55] Storage UP DOWN Deck A if [53] is activated
[13] Effect Parameter Chaser Deck A Play/Pause Layer 1
[36] Effect Parameter Chaser Deck B Play/Pause Layer 1
[Push 55] Storage UP DOWN Deck B if [54] is activated
[14] Effect Parameter Chaser Deck A Play/Pause Layer 2
[37] Effect Parameter Chaser Deck B Play/Pause Layer 2
[56] Main Output Strobe Activate + Value
[15] Effect Parameter Chaser Deck A Play/Pause Layer 3
[38] Effect Parameter Chaser Deck B Play/Pause Layer 3
[57] Fade Type
[16] Effect Parameter Chaser Deck A Play/Pause Layer 4
[39] Effect Parameter Chaser Deck B Play/Pause Layer 4
[58] Fade Time 1/10 Sec
[17] Effect Parameter Chaser Deck A Play/Pause Layer 5
[40] Effect Parameter Chaser Deck B Play/Pause Layer 5
[59] Main Output Strobe Color Red
[18] Effect Parameter Chaser Deck A Play/Pause Layer 6
[41] Effect Parameter Chaser Deck B Play/Pause Layer 6
[60] Main Output Strobe Color Green
[19] Effect Parameter Chaser Deck A Play/Pause Layer 7
[42] Effect Parameter Chaser Deck B Play/Pause Layer 7
[61] Main Output Strobe Color Blue
[20] Effect Parameter Chaser Deck A Play/Pause Layer 8
[43] Effect Parameter Chaser Deck A Play/Pause Layer 8
[62] Main Output Strobe Color White
[21] Cue List View TOGGLE
[44] Cue List View TOGGLE
[63] Audio Input Mute
[22] Cue Storage Place Deck A
[45] Cue Storage Place Deck B
[64] Audio Input Value
[23] Cue List Play/Pause TOGGLE
[46] Cue List Play/Pause TOGGLE
[65] Crossfader
