Step 7), Step 8) Upload And Activation |
Step 7) Uploading A Stand-Alone Show Onto The SD Card Please go to the menu 'Tools' > 'PLEXUS Configuration ' (or 'Ctrl+Alt+P') to call up the PLEXUS Configuration dialog. Press 'Scan' to find your connected PLEXUS.
You can either A) directly save your Stand-Alone Show on an SD card
Or B) you can save your Stand-Alone Show on the SD card that is inserted into your MADRIX PLEXUS. Your PLEXUS must be connected via USB or via Ethernet (network).
Step 8) Activating Stand-Alone Mode Last but not least, you will have to activate Stand-Alone Mode on your MADRIX PLEXUS. A) Activate Stand-Alone Mode manually on the device using the menu (LCD graphics display) and the 5 control buttons (menu Playback). B) 'Call' your device and activate Stand-Alone Mode remotely (menu Playback). Learn more in the chapter Remote Control. C) Use the 'AutoPlay' option to automatically start playing a Scene.
