Tips
This topic includes tips regarding the PLEXUS Configuration dialog and working with PLEXUS Configurations and Stand-Alone Shows.
You can create a Stand-Alone Show without having connected the PLEXUS to the computer.
In order to upload a Stand-Alone Show onto an SD card, either the SD card or the device with the SD card must be connected. You can upload a show onto the SD card of a device via USB or via Ethernet (network).
You can export a Stand-Alone Show directly to the SD card using the 'Export' button in the 'PLEXUS Configuration' dialog.
Art-Net can be used for Stand-Alone Mode. Art-Net output when using the SD card is activated on the device itself. For more info, see LCD Graphics Display (PLEXUS Menus).
