About
You Are Here:  Getting Started >
About
The About window provides a quick overview over software details and legal information.
▪Go to the menu Help > About...
Software
Version
Shows which software version you are currently running and using. It also shows the used software architecture: MADRIX HARDWARE MANAGER is 64-bit only.
Build
Shows when the current software version was created.
Legal Copyright
© 2021 - 2026 inoage GmbH. All rights reserved. See »Imprint And Copyright
End-User License Agreement
Legal Information - Opens this user guide, which includes the End-User License Agreement. See »End-User License Agreement [EULA]
Third Parties
Qt
About Qt - Shows more information about the Qt development framework.
License - Shows the license under which Qt is used.
OpenSSL
License - Shows the licenses under which OpenSSL is used.
Sourcetree
Is a Git client program used for development with thanks. Powered by Atlassian.
Miscellaneous
Left Mouse Click + Hold + Select / Left Mouse Double-Click / Left Mouse Triple-Click - Allows you to select text.
Right Mouse Click > Copy - Allows you to copy text in order to paste the information into an e-mail, for example.
Right Mouse Click > Select All - Selects all text of the currently selected row.
Check For Software Updates
Checks online if a software update is available for downloading. This requires an active internet connection.
Close
Closes the About window.
MADRIX HARDWARE MANAGER User Manual 1.2.
