End-User License Agreement [EULA]
<< Click To Display Table Of Contents >> You Are Here: Legal > End-User License Agreement [EULA] |
A copy of the following license is available as text file in the installation directory, for example C:\Program Files\MadrixHardwareManager\
END-USER LICENSE AGREEMENT FOR INOAGE SOFTWARE
MADRIX HARDWARE MANAGER Software License Agreement
Last Update: 09/2021
This end-user license agreement ('EULA') is a legal agreement between you and the company inoage GmbH ('inoage').
This EULA governs your use of the MADRIX HARDWARE MANAGER Software ('software') but not its acquisition, and thereby does not refer to your purchase contract.
IMPORTANT NOTE
PLEASE CAREFULLY AND THOROUGHLY READ THIS LICENSE AGREEMENT. MAKE SURE THAT YOU FULLY UNDERSTAND ALL INFORMATION. BY CONTINUING THE INSTALLATION AND/OR BY USING THIS SOFTWARE, YOU CONFIRM THAT YOU HAVE READ THE LICENSE AGREEMENT, ACCEPT ALL OF ITS TERMS AND CONDITIONS WITHOUT RESERVATIONS, AND AGREE THAT YOU THUS BECOME LEGALLY BOUND TO THE TERMS OF THIS LICENSE AGREEMENT.
IF YOU DO NOT ACCEPT THESE TERMS AND CONDITIONS, PLEASE STOP THE INSTALLATION PROCESS. YOU CAN DO SO BY CLICKING 'CANCEL'.
IF YOU DO NOT ACCEPT THESE TERMS AND CONDITIONS BUT HAVE ALREADY INSTALLED THE SOFTWARE, PLEASE IMMEDIATELY REMOVE, DELETE, AND DESTROY ALL COPIES OF IT AND ASSOCIATED DOCUMENTS AND DATA.
VALIDITY
This license agreement is only valid for the currently used software version as indicated by the software under the menu 'Help > About... > Version'. This license does not automatically extend to any software updates that may be available in the future.
WARRANTY DISCLAIMER AND LIMITATION OF LIABILITY
The software or any part thereof is licensed 'as is' and without warranty of any kind.
inoage does not grant guarantee on validity for a particular reason, the marketability, or other properties of the product. There is no way to assert a claim to inoage, neither in the legal way nor in other ways. inoage is not responsible for damages, including all disadvantages that are not just limited to the loss of sales, but that are caused due to the use of the product, due to the loss of serviceability of the product, due to misuse, happenings, circumstances, or actions that inoage does not have influence on, no matter if the damages as well as consequential damages are direct or indirect, incidental or consequential; whether they are special damages or others, nor if the damage is caused by the owner of the warranty or a third person.
Any and all such warranties are disclaimed likewise by contributors, licensors, and third parties of third-party software, SDKs, and drivers that enable specific software features.
You accept that you are using the software at your own and sole risk. This also refers to the level of satisfaction regarding its quality, features, and performance.
USAGE RIGHTS
inoage conceded you the limited, non-exclusive right to use this software, and the associated documents and files, in accordance with the terms of this license agreement. The software is 'used' on a computer or similar hardware system when it has been loaded or installed on a storage device of the computer, including but not limited to hard disks, SSDs, non-volatile memory, or similar, or loaded into memory in general. The software usage rights are thus not sold but conceded under license.
Full ownership over the software and all rights that are not expressly granted to you by this license remain with inoage.
SOFTWARE LICENSE AND AUTHORIZED USE
This software is free to use and does not require you to purchase a software license in order to fully unlock the software's features. However, the software's intended purpose is the management and configuration of MADRIX hardware products, which are available for purchase separately.
You are authorized to use the software extensively and according to its features as described above especially, but not limited to, for commercial purposes and production work.
RESTRICTIONS
You are not allowed to or allowed to attempt to and agree to not enable others to:
(a) add to, alter, decode, decompile, delete from, disassemble, decrypt, edit, modify, recompile, rename, reverse-engineer the whole software or any part thereof (except as expressly permitted by this license regarding open-source components), otherwise attempt to derive or gain access to the source code, reduce the compiled binary assembly to human-readable form, or create derivative works from the software or any part thereof;
(b) alter, delete, remove, or obscure any identification of the software, copyright note, or any other notes relating to the property restrictions of the software or any part thereof;
(c) bypass, circumvent, overcome, or work around any technical or non-technical means, restrictions, or limitations that are put in place in or together with the software;
(d) copy the whole or parts of the software's documentation.
PERMISSIONS
(a) You are allowed to install, run, and use the software within the limits of this license.
TERMINATION
This license is effective until terminated. You can terminate it at any time by removing, deleting, and destroying all software files and associated copies. This license will also automatically terminate if you fail to comply with one or more of its clauses. In this case, you must destroy the software and all the associated data, documents, and copies immediately.
COPYRIGHT AND PROPERTY
This software and all of its source codes are the exclusive property of inoage, except where otherwise noted, and are protected by the laws in force on the copyright and the intellectual property. MADRIX is a registered trademark of inoage GmbH. All other company and product names may be trademarks of their respective companies.
THIRD PARTIES
Third-party copyright information and legal notices are accessible or point to further information under the menu 'Help > About...' or corresponding chapters in the software's user manual.
Certain third-party software, including features provided by the operating system, and/or SDKs and drivers are required for specific software features. Please note that all of these tools may be subject to their own, separate end-user license agreements or similar terms and conditions.
CONTACT
You may contact inoage using the following contact details:
inoage GmbH
Wiener Straße 56
01219 Dresden
Germany
Phone: +49 351 862 6869 0
Fax: +49 351 862 6869 68
E-mail: info@madrix.com
Web: https://www.madrix.com
ACCESS
This EULA will also directly be made available as a text file in the installation directory of the software.
CONSENT
By clicking 'I Agree', you hereby confirm that you have read, consent to the described policies, and accepted the license agreement as provided above.
| MADRIX HARDWARE MANAGER User Manual 1.2. |
