Loopback Adapter [127.0.0.1] |
MADRIX 5 features a loopback adapter [by default, with the IP address 127.0.0.1]. MADRIX 5 supports a variety of Ethernet-based network protocols. As such, an active and functioning network connection is required for the communication between tools and equipment, and in order to use these standards. As such, the loopback adapter makes it possible to send and receive network data on the local computer.
The loopback adapter can be used for the following network protocols:
The following points summarize the device: - The loopback adapter is a virtual device that emulates a network adapter. - As such, all normal functionality is provided [including all of its advantages and drawbacks]. - Network data that is sent to the loopback adapter does not leave the local computer. - By default, the IP address is 127.0.0.1. If you are seeing a different IP address, this could be due to corresponding changes that were made in the operating system.
MADRIX 5.6. |
