5-Step Quick Start
First Use
If you want to quickly start using MADRIX, we recommend to at least set up the following initial configuration.
First Use
Step 1] Configure The Virtual LED Matrix
You need to tell MADRIX how your LED installation looks like and how many fixtures [or pixels, voxels] you wish to use. Start by using the Matrix Generator for this task or use the default configuration. By default, MADRIX will have set up 50 x 50 x 1 DMX-based RGB pixels.
Learn more »Matrix Generator
Step 2] Configure Audio Input
Many MADRIX Effects work without audio input. But many MADRIX Effects do require audio input. Configure audio input to see stunning S2L or M2L effects that react to the music in real time.
Learn more »Audio Configuration And ASIO
Step 3] Configure Output
MADRIX needs to communicate with your LED fixtures. The software is very versatile and supports many industry standards and communication protocols to put out data. Because of this, you need to configure which output method MADRIX should use to control your LEDs.
Learn more »OUTPUT Settings
Step 4] Basic User Interface And The Crossfader
MADRIX is very easy to use. To quickly see results, it is recommended learn a few basics about the user interface first.
Learn more »Crossfader And Main Output
Step 5] MADRIX Effects
There is a whole variety of stock effects and lighting visuals available to you. And you can customize all of them. Begin to use the creative power of MADRIX and start using the built-in MADRIX Effects.
Learn more »Effects
MADRIX 3.6h
