SCE Starfield
SCE Starfield
SCE Starfield mainly simulates a field of stars streaming towards the viewer from the center. This creates a depth effect.
BPM - Defines the speed. The default value is 1500. Valid values range from 0 to 9999.
Length - Defines the length of objects' trace. The default value is 25. Valid values range from 1 to 1000.
Count - Defines the number of displayed objects. The default value is 50. Valid values range from 1 to 1000.
Size - Defines the size of objects [in % of the Matrix Size]. The default value is 10. Valid values range from 0.01 to 1000.
Rotation - Defines if the objects rotate around the center [in °]. The default value is 0. Valid values range from -3600 to 3600.
Distortion - Defines the distortion towards the center creating the depth effect [in %]. The default value is 75. Valid values range from 1 to 100.
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Shape is Star.
Invert - Inverts the direction of the effect [from outwards to inwards/from near to far].
MADRIX 3.6i
