SCE Plasma
SCE Plasma
Context Menu
SCE Plasma creates a liquid and moving color gradient.
Color - Defines the color via a Color Gradient and various options.
Stretch - Defines the stretch or compression factor at which the visuals are displayed [X, Y, Z, XY, YZ]. The default values are 1, 1, 1, 1.00, 1.00. Valid values range from 0.01 to 10.
Distance - Defines how much of the visuals are displayed; like a zoom level. The default value is 1. Valid values range from 0.01 to 10.
Context Menu
A context menu allows you to quickly make changes to the colors.
Right Mouse Click - Click with your right mouse button on the color gradient to call up the context menu.
Open... - Loads a previously saved Color Table file from an external file [of the file type *.mctx].
Save... - Saves the current colors as a Color Table file [of the file type *.mctx].
Copy - Copies the current colors into the clipboard as a duplicate.
Paste - Applies all colors from the clipboard to the currently focused color control [Colors, M2L Colors].
Defaults - Restores all default gradient colors.
MADRIX 3.6i
