SCE Metaballs creates objects that morph into each other creating a fluent animation.
Learn more »Layers |
| ▪ | BPM - Defines the speed. The default value is 1200. Valid values range from 0 to 9999.
Learn more »Using BPM Control |
| ▪ | Count - Defines the number of objects. The default value is 5. Valid values range from 1 to 20. |
| ▪ | Size - Defines the size of objects [in %]. The default value is 20. Valid values range from 1 to 100. |
| ▪ | Outer Glow - Defines the outer shimmer of objects. The default value is 20. Valid values range from 1 to 100. |
| ▪ | Inner Glow - Defines the inner gleam of objects which are not filled. The default value is 20. Valid values range from 1 to 100. |
| ▪ | Border - Is only available for 2D outlined shapes or 3D unfilled shapes. Defines how thick the outer line [border] of objects is. The default value is 20. Valid values range from 1 to 100. |
| ▪ | Influence - Is only available for Motion Type Swarm. Defines a radius in which objects influence other objects [in %]. The higher the value, the more visible the swarm behavior. The default value is 15. Valid values range from 0 to 100. |
| ▪ | Separation - Is only available for Motion Type Swarm. Defines how close objects can be to each other [in %]. The higher the value, the more space will be between objects. The default value is 5. Valid values range from 0 to 100. |
Linear - A linear distribution is used to increase the size regularly.
Quadratic - The majority of objects will be smaller than the rest.
SQRT - Using a square root function the majority of objects will be larger.
Cubic - Uses a cubic distribution with mixed sizes.
Scale - Is only available for Random Distribution Mode. It allows you to generally increase or decrease the size of objects.
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Mode is Circle Filled.
- Set up at least 2 colors if you want to define a second shape. Both shapes and both colors will then be morphed together. By default, the second shape equals the first shape.
- Deselect Auto Adjustment [Color Mixing Link] to set up a different, second shape.
- When using at least 2 colors or using the Color Table Random Mode [RND], you can set up the Color Mixing Sharpness . It allows you to choose how intensely the colors are mixed [Very Blurry, Blurry, Slightly Blurry, Medium, Slightly Clear, Clear, or Very Clear]. The default Color Mixing Sharpness is Medium.
Shape Rotation Type - Is only available for specific Shapes. Defines the angle in which objects are rotated [0°, 90°, 180°, 270°, Random].
Motion Type - Choose how objects move and behave. The default value is Random.
Random - Objects move randomly and independently of each other.
Swarm - Objects react according to a swarm intelligence and thus imitate their movement behavior.
