SCE Color Change
SCE Color Change automatically changes colors.
BPM - Defines the speed. You can either use BPM or Time. The default value is 60. Valid values range from 0 to 9999.
Time - Defines the time interval a color is displayed [in s]. You can either use BPM or Time Slot. The default value is 1. Valid values range from 0.01 to 9999.
