S2L Level Color
S2L Level Color displays the loudness of the audio input with the help of color. The louder the input, the brighter the effect.
Colors - Opens the Color Gradient to specify the colors. The default color is White, Black.
Fade Out / In - Defines how fast MADRIX displays color. You can specify the fade-in speed as well as the fade-out speed. The default values are 120 and 120. Valid values range from 1 to 3000.
Mode - Allows you to choose the mode [Mono, Stereo Linear, Stereo Radial]. This heavily influences the visual outcome of the effect.
Direction - Allows you to choose the direction. This includes all directions for 2D and 3D mode. The default value is Right. Learn more »Using Directions
