S2L Level Meter displays the audio input level. By default, the left audio channel and the right audio channel are shown.
Learn more »Layers |
| ▪ | Color - Opens the Color Gradient to specify the colors. The default color is White, Black.
Learn more »Using Colors And Intensity |
| ▪ | Drop - Defines how quickly the effect is shown. The default value is 50. Valid values range from 1 to 100. |
| ▪ | Fade - Defines how fast MADRIX displays the effect [in %]. The default value is 3000. Valid values range from 1 to 3000. |
| ▪ | Width 1 - Defines the first size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 50. Valid values range from 0.01 to 100. |
| ▪ | Pitch 1 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 50. Valid values range from 0.01 to 100. |
| ▪ | Width 2 - Defines the second size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100. |
| ▪ | Pitch 2 - Defines the first distance between objects depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100. |
View Logarithmic - Displays the effect in a logarithmic way.
Mono - Deactivates Stereo and only uses 1 audio channel.
Direction/Mode - Allows you to choose the direction, including Cross Mode. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default Direction is Top. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. The default Shape is Filled.
