S2L EQ / Spectrum displays a real-time equalization and visualization of the audio signal [i.e., audio spectrum].
[In MADRIX 2, S2L EQ / Spectrum was named S2L Equalizer.]
Learn more »Layers |
| ▪ | Colors - Opens the Color Gradient to specify the colors. The default color is Red, Orange, Green.
Learn more »Using Colors And Intensity |
| ▪ | Drop - Defines how quickly spectrum bars are not displayed any more and drop out of the matrix [in %]. The default value is 50. Valid values range from 1 to 100. |
| ▪ | Fade - Defines how fast MADRIX displays the effect [in %]. The default value is 3000. Valid values range from 1 to 3000. |
| ▪ | Width 1 - Defines the first size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 0.1. Valid values range from 0.01 to 100. |
| ▪ | Pitch 1 - Defines the first distance between spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 0.1. Valid values range from 0.01 to 100. |
| ▪ | Width 2 - Defines the second size of spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100. |
| ▪ | Pitch 2 - Defines the first distance between spectrum bars depending on the direction [in % of the Matrix Size]. The default value is 100. Valid values range from 0.01 to 100. |
Logarithmic - Displays the spectrum in a logarithmic way.
Dynamic range Control - Visually amplifies and balances frequencies to get a more interesting spectrum.
Shift - Shifts the position of equalizer bands [in %]. By default, lower frequencies are shown to the left and high frequencies are shown to the left. The default value is 0. Valid values range from 0 to 100.
Direction/Mode - Allows you to choose the direction, including Cross Mode. This includes all directions for 2D and 3D mode. This heavily influences the visual outcome of the effect. The default Direction is Top. Learn more »Using Directions
Shape - Allows you to choose a specific shape for objects. A certain Size is required before a shape becomes visible. The default Shape is Filled.
