M2L Tubes displays the music in form of tubes.
[In MADRIX 2, M2L Tubes was named M2L Interval Tubes.]
Learn more »Layers |
| ▪ | Fade - Defines how fast MADRIX displays the effect [in %]. The default value is 60. Valid values range from 1 to 3000. |
| ▪ | Size 1 - Defines the first size of tubes depending on the direction [in %]. The default value is 10. Valid values range from 0.01 to 100. |
| ▪ | Pitch 1 - Defines the first distance between tubes depending on the direction [in %]. The default value is 10. Valid values range from 0.01 to 100. |
| ▪ | Size 2 - Defines the second size of tubes depending on the direction [in %]. The default value is 100. Valid values range from 0.01 to 100. |
| ▪ | Pitch 2 - Defines the first distance between objects depending on the direction [in %]. The default value is 100. Valid values range from 0.01 to 100. |
| ▪ | Alpha Mix - Defines the upper limit of how much alpha is added to each object [in %] . Alpha Mix will be visible when using additional Layers. The default value is 100. Valid values range from 0 to 100. |
| ▪ | Tone Range - Defines the range of tones analyzed and used by setting a minimum and a maximum value. Narrow the range if your audio signal does not include a wide range of tones to avoid a lot of empty space where no objects are shown. The default values are C1 and C9. Valid values range from C-1 to G9. |
Vertical Mode - Activates or deactivates the use of vertical objects. All 3 modes can be used at the same time.
Horizontal Mode - Activates or deactivates the use of horizontal objects. All 3 modes can be used at the same time.
Depth Mode - Activates or deactivates the use of objects in the depth. All 3 modes can be used at the same time.
Mode - Allows you to choose which musical parameter is used [Tone, Interval, Base Type].
