DMX-IN Remote Editor
▪Introduction
▪Initial Configuration
▪Overview
▪Keyboard Shortcuts
▪Configuration
▪Modifiers
▪Examples
Any DMX input signal can be used to control MADRIX remotely. While you can use preconfigured DMX protocols, you can also set up such a configuration according to your needs with the help of the DMX-IN Remote Editor. This topic describes how to use the DMX-IN Remote Editor.
▪Make sure to configure your DMX device first.
[For example, DMX devices can be consoles, DMX desks, fader boards, other DMX interfaces, etc.]
▪Set up DMX Input.
▪Learn more »DMX-IN / Art-Net Remote / sACN Input
▪Go to Preferences > Device Manager... > DMX Input
▪MIDI Remote Control EditClick Edit... to open the DMX-IN Remote Editor
▪A new window will open.
▪If you are creating a new DMX protocol, the list will be empty.
▪If you are modifying an existing DMX protocol map, the list will already contain all preconfigured settings.
Add - Adds a new item to the list.
Remove - Removes the currently selected list items.
MIDI Remote Editor - Copy Entries
Duplicate/Copy - Copies and duplicates the currently selected list item. The new item will be added to the list right after the selected item. You can change its settings afterwards.
MIDI Remote Editor: Navigation
Navigation - Allows you to select the next or previous list item.
New - Creates a new configuration while deleting all previous list items with your permission.
- Allows you to create an empty DMX Remote Configuration [Empty] or load a preconfigured DMX protocol [Simple, General, Advanced].
Open - Loads a previously saved DMX Remote Configuration file into the DMX-In Remote Editor from an external file [of the file type *.mdrx].
Save - Saves the current DMX Remote Configuration to an external file [of the file type *.mdrx].
Save As - Save the current DMX Remote Configuration to another external file [of the file type *.mdrx]. Simply enter a name and click Save.
Assign A MIDI Control To A Function
Assign - Allows you to assign a control of your DMX controller to a function in MADRIX.
- 1] Activate Assign, select an list item you created and move the control of your DMX controller.
- 2] In most cases, MADRIX will automatically recognize the identify the DMX Channel, Control Type, and Interaction for the control. Learn more Configuration
MIDI Remote Editor: Test
Test - Allows you to test single list items and their functionality on the MADRIX user interface, while having the DMX-IN Remote Editor still opened.
- Activate Test, then use the control on your DMX controller. You can see if the control works as expected on the MADRIX user interface.
- If Test is activated, MADRIX will receive the signal directly and not the DMX-IN Remote Editor.
- Test is also useful for testing modifiers. Learn more Modifiers
MIDI Remote Editor: Configuration Name
Configuration Name - Allows you to type in an individual description for your DMX Remote Configuration.
- Once saved, you will be able to select your DMX Remote Configuration under Preferences > Device Manager... > MIDI > Remote Control and MADRIX will use this label.
Keyboard Shortcuts
Ctrl + A
Selects all items in the list.
Ctrl + E [hold]
Activates Assign, while holding this shortcut.
Ctrl + N
Creates a new configuration.
Ctrl + O
Opens a configuration.
Ctrl + S
Saves a configuration.
Ctrl + T [hold]
Activates Test, while holding this shortcut.
Del
Removes selected items from the list.
Arrow Up
Navigates upwards in the list.
Arrow Down
Navigates downwards in the list.
Double-click on an item
Double-click on a head row of the list
Sorts the list alphabetically according to the column [ascending or descending].
Configuration
▪Each list item represents 1 DMX remote functionality using 1 DMX control [i.e., button, fader, etc.].
▪Configure each list item as required.
▪Configure each column of an list item.
▪Add or remove list items to add or remove the functionality you require.
Function
MIDI Remote Editor: Function
1] Create a new item with +
Or select a list item and perform a double-click with your mouse on the column Function
2] Select the general topic [e.g., Audio]
3] Select the exact function you wish to configure [e.g., Volume]
DMX Channel
DMX-IN Remote Editor: DMX Channel
A] Click Assign, select a list item and use a control on your DMX controller. In most cases, MADRIX will automatically recognize the DMX Channel, Control Type, and Interaction.
B] Or first select a list item and perform a double-click with your mouse on the column DMX Channel. Second, enter the correct DMX channel [e.g., CH01 for channel 01].
Control Type
B] Or first select a list item and perform a double-click with your mouse on the column Control Type. Second, select the type of the control of your DMX controller [e.g., Button].
▪Fader / Knob - Defines a fader or knob control that has a wide range of available values with starting point and end point.
▪Button - Defines a button control that has two states [On or Off]; often as switch, push button, or button.
Interaction
MIDI Remote Editor: Interaction
B] Or first select a list item and perform a double-click with your mouse on the column Interaction. Second, select the mode [e.g., Toggle].
Toggle - Defines that the Control Type only has two states [On or Off]. Is usually used for Button.
Absolute - Defines that the Control Type uses all available values [e.g., 0 to 255]. Is usually used for Fader / Knob.
Invert
MIDI Remote Editor: Invert
1] Select a list item and perform a double-click with your mouse on the column Invert.
2] The item will change between No and Yes
- If Yes is selected, all values of this control will be inverted. That means for example that 0 becomes 255 and 255 becomes 0.
- No is the default value. No values will be inverted.
Condition
MIDI Remote Editor: Condition
1] Select a list item and perform a double-click with your mouse on the column Cond.
2] Select the condition [e.g., None].
- If you select a State, click Yes or No
- If you select a Value, select the according number
MIN, MAX,
Description
▪Select an item and perform a double-click with your mouse on the column MIN, MAX, or Description. Enter the desired value or text.
▪MIN - Defines a minimum value for this functionality. The default value is 0.
MAX - Defines requires a maximum value for this functionality.
- For example, the Master Fader has a maximum value of 255, or you may want to set the maximum Fade Time to 10 seconds.
▪Description - Allows you to enter a text to describe the functionality.
- [By default, the name of the function will automatically be entered].
Modifiers
The DMX-IN Remote Editor allows you to create advanced DMX configurations.
▪Modifiers allow you to set certain conditions.
▪In general, these are the steps to follow:
1] Create a new item with + or select a list item and perform a double-click with your mouse on the column Function
2] Select Modifier
3] Select a State or Value
4] Create a new list item and configure its Function or use an existing list item
5] Assign the condition to this function.
Learn more Condition
State
▪State - Creates a requirement/condition that is required before the function will work.
▪You can define up to 8 States.
▪Valid values are Yes [Value = 1] or No [Value = 0].
▪Example:
- List item 1 defines a button as a Modifier, State 1 to be toggled. When pressed, State 1 is active [On, Yes]. When not pressed, State 1 is not active [Off, No] .
- List item 2 is a function to control the Master [Global Master]. A Condition was set up for this functionality. If MADRIX receives value 1 [Yes] from State 1, the function can be used.
- Because of the Condition, the Master Fader can only be used when the button is pressed at the same time:
Modifier Example State 1
- If no condition is assigned, the fader can be moved and the Master Fader of MADRIX will always respond accordingly:
Modifier Example State 2
- When Test is activated, MADRIX shows the status of a State in the MIDI Remote Editor. A green button indicates status Yes, a gray button indicates status No.
Value
▪Value - Allows to add several functions to one or more controls of the MIDI controller by combining it with other available controls.
▪You can define up to 8 Values.
▪Valid values range from 0 to 255.
▪Example:
- Your DMX controller may only have 2 faders.
- But you would want to control the Master, the Speed Master Left, and the Speed Master Right with these two faders.
- In this example, we have configured the first fader to activate three different configurations for the second fader.
- If fader 1 is set to 0, the second fader will act as the Master.
- If fader 1 is set to 127, the second fader will act as Speed Master Left.
- If fader 1 is set to 255, the second fader will act as Speed Master Right.
- Depending on how the first fader is set up, the modifier value changes from 0 to 255. MADRIX checks this value and allows the fader to control the corresponding function on the MADRIX user interface.
▪Note: Always assign the correct values to modifier and function.
▪When Test is activated, MADRIX shows the status of a Value in the DMX-IN Remote Editor.
Examples
Example 1
▪You wish to use single buttons of your DMX controller for each Storage Place.
▪Use + to create a new function.
▪Select Storage Left > Place +Fade
▪Use Assign to match your button to this function. Disable Assign again when done.
▪Set MAX to 0 in order to trigger Storage Left S1 P1 [Storage 1 Place 1].
▪Repeat the steps and set up MAX for each Storage Place you wish to control.
- MAX will always have a value that is -1 compared to the actual Storage Place index number [e.g., set MAX to 6 in order to control S1 P7]
▪Use Storage Right > Place +Fade and repeat the steps accordingly to control the Storage Places on the right side.
