Using The Crossfader To Switch Effects
Step By Step
First, select an effect you have already programmed from Storage Area A. Next, choose an effect placed in Storage Area B.
For example, you have set and selected the first effect in Storage A–1 and the second effect in Storage B–1. Now, you can simply cross-fade between both Storage Places.
Fade Area plus Fader
In the example below we moved the fader to the middle using a white-fade. You will see a mix of both effects in the output preview.
Graphical User Interface
