Examples
Preinstalled Files
If you would like to see some examples, various
setups,
effects,
scripts,
and color tables
are already installed on your PC if you have enabled this option during the installation process:
Install Examples
You can find the examples on your hard disk. Please navigate to C:\Users\USERNAME\Documents\MADRIX\
(Please choose your Windows username for USERNAME).
You will find the folders "setups", "effects", "scripts", and "colortables" where you can save your files. Each folder also contains a link "Samples". This link will take you to another folder that contains various examples.
More Information
Learn more about the file types used in MADRIX: File Types.
