SCE Shapes
SCE Shapes
The SCE Shapes effect randomly renders objects with different shapes in a color you have selected.
There are different modes for colors, speed, fade times, number of objects (Count), Width, Border, and different types of shapes.
SCE Shapes Example
Available ShapesThe picture shows available modes/shapes for this effect. You have to play with the parameters BPM, Fade, Count, Width, and Border to see the possibilities you have with this effect. Be creative and try to combine this effect with others by using layers and different mix modes.
