SCE Radial
SCE Radial
The SCE Radial offers moving colors in three different radial modes.
Set up the "BPM" speed and various colors to influence the outcome. Values for red, green, blue, and white may be used.
SCE Radial Example
You can either enter values directly over the keyboard or use the fader box with your mouse.
Use the input field "Length" to define the extent of the shapes. Change X and Y coordinates to modify the "Center" of a radial effect.
Mode ButtonThis drop-down button allows to select different modes. You can choose from three different types of effect: "Circle", "Radar", and "Helix". Select a mode after clicking the button to activate the particular mode.
Options and ModesWith the sinus buttons you can define the color mode (one color or multi-color mode.) Direction buttons allow to set up the motion direction. Additionally, you will find two moving mode buttons to define inside-out or outside-in mode.
"Factor" and "Amplitude" are available when "Circle" or "Helix" is selected. "Factor" influences the way the function is drawn. It increases the number of waves. "Amplitude" increases the intensity of those waves.
