S2L Level Ring |
For setting up colors simply press the "Color Table" button. "BPM" sets up the speed with which the effect is displayed and updated. If you would like to have slow movements (updates) move the fader to the left, or put in low numerical values. Values in a range from 1 to 9999 are supported. If you move the fade to the right, the update speed increases and the band moves faster. You can use the "Amplify" function as a visual amplifier of the audio signal. Values will be displayed more intensely as a result. The more you move the fader to the right, the stronger will be the visual amplification of single signals. The "View Log" button switches to logarithmic rendering of the signals. Depending on the kind of music as well as its volume, we suggest to try what fits best.
