Firmware Updates
You Are Here:  Technical Support >
Firmware Updates
It is highly recommended to update the firmware should a new firmware version become available.
MADRIX HARDWARE MANAGER
To update your devices, please use the separate MADRIX HARDWARE MANAGER software.
Learn more »MADRIX HARDWARE MANAGER [USB / Ethernet]
Available Firmware Updates
Sorted in descending order.
Latest Version
Highlights
STELLA Firmware
6.12.0907
Release Date
July 2026
▪Now uses the Device Name as the HTML Title for the Web Configuration (#12861).
▪Changed the maximum available number of characters from 18 to 17 for Short Name (Art-Net) and from 64 to 63 for Name (Art-Net Long Name) in the Web Configuration (#12840).
▪Updated and optimized system resources (#12884).
▪Added supported UCS protocols to the user manual (#13259).
▪Fixed the layout and controls alignment of the Special Commands section in the Web Configuration (#9168).
STELLA Firmware
6.11.0883
Release Date
January 2026
▪Fixed an issue that turned off the status LEDs on the device after a reset to factory default settings (#12781).
STELLA Firmware
6.10.0879
▪Now supports the Preview Flag of Streaming ACN [sACN] to discard data that is intended for visualization purposes only (#12733).
▪Fixed a critical issue that could cause data output to stop in rare cases when receiving data unexpectedly while RDM was enabled (#12688).
STELLA Firmware
6.05.0924
Release Date
December 2024
▪Now provides the used network Gateway in a specific Art-Net reply (#11038).
▪Fixed an important issue that caused the device to only report ArtTodData of the first port, and not both ports, in case both ports were set to the same DMX Universe (#10730).
STELLA Firmware
6.04.0889
Release Date
May 2024
▪Art-Net 4: Added Squawking to the PollReply for better device identification in [software or hardware] controllers who support this feature (#10691).
STELLA Firmware
6.03.0862
Release Date
December 2023
▪Web Configuration: Improved the NetBIOS functionality by writing out the full address for web browsers (#10355).
▪Improved discarding of ArtRdm draft packets by additionally checking the ArtRdm version flag (#10363).
▪Fixed an issue with the 'Node Report' field of the Art-Net implementation (#10370).
STELLA Firmware
6.02.7429
▪Web Configuration: Added NetBIOS functionality and information in the Device Information section to find and connect to devices using the NetBIOS name instead of the IP address (#10246).
STELLA Firmware
6.01.7426
Release Date
September 2023
▪Web Configuration: Now shows the RDM UID Count for discovered and connected RDM devices (#9806, #9947).
▪Web Configuration: Checkmarks for checkboxes are now shown in the correct green accent color (#9963).
▪Fixed an issue that did ignore the BindIndex via ArtAdress; resulting in users only being able to set the first universe via ArtAddress (#10134).
STELLA Firmware
4.07.7413
Release Date
April 2023
▪Fixed an issue that did not correctly join and leave universe assignments in case of sACN (#9575).
STELLA Firmware
4.06.7408
Release Date
April 2023
▪Fixed an issue that uncontrolledly added zeros or possibly data to the HTML source code of the web configuration via a Firmware's hash value (#9569).
STELLA Firmware
4.05.7407
Release Date
January 2023
▪Improved reliability by ensuring that network settings are always properly saved (#9213).
▪Added the development cd hash to the firmware version to the Device Information section (#9361).
STELLA Firmware
4.03.7401
MADRIX Version
MADRIX 5.5c
Release Date
October 2022
STELLA Firmware
4.02.7398
MADRIX Version
MADRIX 5.5b
Release Date
August 2022
▪The bootloader version can now be provided by the firmware over USB (#8874).
STELLA Firmware
4.01.7397
Bootloader
4.01.9396
MADRIX Version
MADRIX 5.5a
Release Date
July 2022
▪Added support for new hardware components (#8029).
▪Bootloader 4.0: Fixed an issue that did not always respond to firmware packets being sent over Art-Net (#8027).
▪Bootloader 4.0: Added support for new hardware components (#8028).
▪Bootloader 4.0: A single Art-Net PollReply is being sent after starting and remaining in the bootloader (#8032).
▪Fixed an issue that did not disable Send Full Frames when deactivating it for both ports (#8606).
STELLA Firmware
3.03.7390
MADRIX Version
MADRIX 5.4h
Release Date
April 2022
▪Web Configuration: Added the possibility to edit the ShortName identifier for Art-Net (#8159).
▪Web Configuration: Added option 'Send White Frames Continually' for the 'In Case Of Missing Network Data' setting (#8169).
▪Web Configuration: Now shows the uptime of the device (#8183).
▪Increased operational robustness of the device by discarding RDM responses that are only received from RDM Responders after the valid response time (#8183).
STELLA Firmware
3.02.7387
MADRIX Version
MADRIX 5.4g
Release Date
March 2022
STELLA Firmware
3.01.7385
MADRIX Version
MADRIX 5.4f
Release Date
January 2022
▪The bootloader can now read the hardware revision/model over USB (#7802).
▪Supports the RDM flag per universe/port according to the latest Art-Net 4 protocol revision 1.4dd2 (#7904).
▪Fixed a critical issue that could cause the bootloader on hardware revision 1.2 to freeze at startup with the status-LED Power being permanently on (#7808).
STELLA Firmware
3.00.7380
MADRIX Version
MADRIX 5.4e
Release Date
October 2021
▪Updated the system of the device (#6971, #7114, #7504).
▪Updated the bootloader of the device (#7544).
▪A single bootloader now supports both Ethernet ports (#7695).
▪A maximum of 170 RDM Responders can now be discovered per port (#7479).
▪Improved the timing of RDM packets (#7479).
▪RDM packets are now also forwarded during a discovery of connected RDM Responders (#6726).
▪All RDM packets that are not processed by the device itself are forwarded unchanged to the RDM Controller (#7639).
▪Changes regarding connected RDM Responders are now also evaluated with the help of the UID itself in addition to the UID count (#7683).
▪Fixed an issue that stilled showed the previous IP address when setting a new IP address via ArtIpProg over Art-Net (#7347).
▪Fixed an issue that did not consistently initiate a PollReply when changing settings using the web configuration page (#7689).
STELLA Firmware
2.06.7355
MADRIX Version
MADRIX 5.4c
Release Date
July 2021
▪Web configuration page: Added the option to set the Output Intensity (#7317).
▪Web configuration page: Added the option to set the Upper Intensity Limit (#7317).
▪Web configuration page: Added the option to reboot the device (#7403).
▪Web configuration page: Added the option to reset the device to factory default settings (#7403).
▪Fixed an issue that could prevent changed settings from being saved in rare cases after a power cycle (#5382).
▪Fixed an issue that did not show the favicon in web browsers (#6460).
▪Fixed that the option Send The Last Received Frame Continually did not work correctly when a universe failed after having received two universes of data (#7344).
STELLA Firmware
2.05.7308
MADRIX Version
MADRIX 5.4b
Release Date
May 2021
▪The device now replies with ArtTodData to an ArtTodControl request for improved compatibility with Art-Net 4 (#6958).
▪Improved and streamlined how the device replies to ArtTodData with Unicast, Directed Broadcast, or Limited Broadcast (#6959).
STELLA Firmware
2.04.7304
MADRIX Version
MADRIX 5.4a
Release Date
February 2021
▪Web configuration page: Fixed an incorrect IP address shown for sACN Multicast Mode (#6562).
▪Fixed a critical issue that could halt the device when receiving an Art-Net OpIpProg request (#6852).
▪Fixed an issue that did not save the chosen value for the 'In Case Of Network Data Timeout' setting for the second port (#6899).
▪Fixed an issue that did send back the On/Off state of RDM for Port 2 incorrectly in the Art-Net PollReply (#6915).
STELLA Firmware
2.03.7291
MADRIX Version
MADRIX 5.4
Release Date
December 2020
▪Fixed minor issues.
STELLA Firmware
2.03.7261
MADRIX Version
MADRIX 5.3
Release Date
May 2020
STELLA Firmware
2.03.7259
MADRIX Version
MADRIX 5.2
Release Date
November 2019
▪Channel Order 4-1-2-3 has been added.
▪Now clears the input buffer in order to discard obsolete and incorrect RDM packages before sending out new requests to avoid that packages cannot be assigned and processed correctly due to timeouts.
STELLA Firmware
2.03.7252
MADRIX Version
MADRIX 5.1a
Release Date
August 2019
▪Fixed an issue that could make the device become unresponsive when using RDM and both ports at the same time.
STELLA Firmware
2.03.7236
MADRIX Version
MADRIX 5.1
Release Date
June 2019
▪Fixed an issue that only applied a new IP address that was set over USB after a power cycle.
▪Fixed an issue that did continue to send the last frame that was received over USB under certain circumstances although new network data was received.
▪Fixed an issue that did not allow receiving data over USB when merging data from Art-Net and sACN.
▪Fixed an issue that allowed special characters and control characters [ASCII] in names and descriptions, which are not filtered out.
STELLA Firmware
2.02.7206
MADRIX Version
MADRIX 5.0e
Release Date
February 2019
▪Added RDM support.
▪Added support for 2 Ethernet ports [Model V1.2 required].
▪Added daisy-chain support [Model V1.2 required].
▪Web configuration page: Universes up to number 32,768 can now be assigned.
▪During normal operation, pressing the Reset button now sends an Art-Net PollReply [e.g., Device Manager] and a MADRIX PollReply [MADRIX Device Configuration].
▪Changed the Art-Net PollReply to assign a separate BindIdx to each universe.
▪Fixed an issue that did only apply a new IP address after changing it over USB after disconnecting it from power first.
STELLA Firmware
2.01.7147
MADRIX Version
MADRIX 5.0d
Release Date
August 2018
▪Fixed an issue that did only sent out Art-Net data when setting Port 2  to input.
▪Fixed a critical issue that could halt the device in rare cases.
STELLA Firmware
2.00.7140
MADRIX Version
MADRIX 5.0b
Release Date
July 2018
▪Web configuration page: Updated the visual appearance for MADRIX 5.
▪Web configuration page: Network universes are now also shown in hexadecimal notation in addition to the decimal notation.
▪Added support for Streaming ACN [sACN] for input and output.
▪You can now choose the network data source: Art-Net, Streaming ACN, or Art-Net And sACN.
▪You can set the Start Channel for each port.
▪You can change the Channel Order for the output.
▪Added support for ArtSync.
STELLA Firmware
1.04.7082
MADRIX Version
MADRIX 3.6h
Release Date
February 2018
▪Added 4 distinct options for sending data output in case of data connection loss [only available in the web configuration tool]:
- Send The Last Received Frame Continually
- Send Black Frames Continually
- Stop Sending After Sending A Black Frame
- Stop Sending
▪Increased the minimum output frequency that is sent on each port from 10 FPS to 20 FPS [in order to ensure functionality with lighting fixtures that are not working correctly when receiving low frame rates].
▪Fixed an issue that could prevent reception of DMX input when Sync Mode had been enabled in the MADRIX 3 Software.
STELLA Firmware
1.02.7035
MADRIX Version
MADRIX 3.6f
Release Date
May 2017
▪Fixed an issue that could leave the status LEDs permanently on when using the ArtAddress functionality for Art-Net to switch from normal operation to off while the status LEDs were currently active.
STELLA Firmware
1.02.6346
MADRIX Version
MADRIX 3.6d
Release Date
December 2016
▪Sensor data: Devices can now report back if voltage is connected/disconnected over USB [Voltage USB].
▪Sensor data: Devices can now report back which voltage is used for Power [Voltage Power].
▪Sensor data: For STELLA models V1.1 and higher, devices can now report back the ambient temperature [Temperature].
▪Fixed an issue that could make the device become unresponsive under certain circumstances when connecting, disconnecting, and calling up the website several times in a row.
STELLA Firmware
1.01.6168
MADRIX Version
MADRIX 3.6a
Release Date
July 2016
▪Web configuration page: Added Voltage to the Device Information section.
▪Web configuration page: Added the Refresh button to always show the latest information that was last saved on the device in the web browser [instead of using a browser refresh which may change settings again].
STELLA Firmware
1.01.6147
MADRIX Version
MADRIX 3.6
Release Date
May 2016
STELLA Firmware
1.00.6127
MADRIX Version
MADRIX 3.6 RC
Release Date
May 2016
▪Initial firmware release.
