|  | Introduction Stand-Alone Mode is an important feature of the MADRIX PLEXUS. 1x DMX-OUT, 2x DMX-OUT, or Art-Net is available in Stand-Alone Mode. Normally, a computer runs the MADRIX software live and thereby controls the LED installation. In contrast, the Stand-Alone Mode of the MADRIX PLEXUS can be used to control LED installations without the need for a computer during the show. The PLEXUS can use an SD card (SD or SDHC) on which a Stand-Alone Show can be saved. But first, it is necessary to create such a Stand-Alone Show.Please note: When shipped, the SD card of the PLEXUS will already have a sample show on it.
 Please read the following chapter carefully in order to learn how to create a MADRIX PLEXUS Stand-Alone Show.   Basic Workflow (Step By Step) In order to create a show file, please follow these steps:(Details are given in the next chapters for each step.)
| Step 1) | Configure your virtual LED matrix according to your LED installation. (In MADRIX, use the Matrix Generator or the Patch Editor for this task.)
| Step 2) | Create the MADRIX effects you wish to use.(Use the graphical user interface of MADRIX for this task.)
| Step 3) | Create a Cue List, if you wish to use it during the recording. If not, simply skip this step and you will create a live record.
 (In MADRIX, navigate to the menu 'Window' > 'Cue List...'.)
| Step 4) | Record your effects by creating a MADRIX Record file (*.mrec).(In MADRIX, use the Recording window for this task.)
| Step 5) | Convert the Record file (*.mrec) into a DMX Data file (*.dxd).(In MADRIX, use the Recording window for this task.)
| Step 6) | Create a PLEXUS Configuration. This will be your Stand-Alone Show!(In MADRIX, use the PLEXUS Configuration window for this task.)
| Step 7) | Upload your Stand-Alone Show onto the SD card.(In MADRIX, use the PLEXUS Configuration window for this task.)
| Step 8) | Activate Stand-Alone Mode for the MADRIX PLEXUS.(In MADRIX, use the PLEXUS Configuration window for this task.)
 |     9Continue with Step 1)   |
