DMX-IN [Standard Protocol]
You Are Here:  Input, Interoperability, And Remote Control > DMX-IN / Art-Net Remote / sACN Input >
The Standard Protocol is a pre-configured DMX protocol [or profile] you can use for Remote Control.
▪Standard Protocol uses 36 DMX channels.
▪Valid incoming DMX values are 0 - 255.
DMX Channel
Remote Control Function
DMX Values [Allowed Input]
DMX Values [Mapped]
DMX Values [Currently Used]
Functionality
Comment
01
Output Master
0 - 255
0 - 255
0 - 255
0 - 255
Control the overall intensity.
02
Deck A Storage Index
0 - 255
0 - 255
0 - 255
Storage, Deck A, 1 - 256
Choose Storage 1 to 256 on the left side.
03
Deck A Place Index + Fade
0 - 255
0 - 255
0 - 255
Storage Place, Deck A, 1 - 256
Choose your Storage Place in the selected Storage on the left side. A fade of the crossfader is applied automatically according to the Fade Time.
04
Fade In 1/10 Seconds
0 - 255
0 - 100
0 - 255
Fade Time, 0 - 10s
0 = 0s
127 = 5s
255 = 10s
Steps of 2 or 3 = 0.1s
Set up the Fade Time of the crossfader in tenths of a second.
05
Fade Type
0 - 255
0 - 255
0 - 14
0 = XF
1 = WF
2 = BF
3 = Wipe X
4 = Wipe Y
5 = Wipe XC
6 = Wipe YC
7 = Slide X
8 = Slide Y
9 = Slide XC
10 = Slide YC
11 = Wipe Z
12 = Wipe ZC
13 = Slide Z
14 = Slide ZC
Set up the Fade Type of the crossfader.
06
Deck A Speed Master
0 - 255
0 - 255
0 - 255
Control the overall speed of Deck A.
07
Output Filter Color Mode
0 - 255
0 - 255
0 - 3
0 = Allow Through
1 = Filter Out
2 = Colorize
3 = Ignore
Choose the Color Mode of the Output Filter.
08
Output Filter Color Red
0 - 255
0 - 255
0 - 255
09
Output Filter Color Green
0 - 255
0 - 255
0 - 255
10
Output Filter Color Blue
0 - 255
0 - 255
0 - 255
11
Output Filter Color White
0 - 255
0 - 255
0 - 255
12
Output Filter
0 - 255
0 - 255
0 - 102
0 = No FX
1 = Blur
2 = Blur B-Spline
3 = Blur Catmull Rom
4 = Blur Gauss
5 = Blur Mitchell
6 = Sharpen
7 = XYZ (Brightness Graph)
8 = XZY (Brightness Graph)
9 = YXZ (Brightness Graph)
10 = Brighten (Color Correction)
11 = Darken (Color Correction)
12 = Grayscale (Color Correction)
13 = Invert Color (Color Correction)
14 = BGR
15 = BRG
16 = GRB
17 = GBR
18 = RBG
19 = WBGR
20 = WBRG
21 = WGRB
22 = WGBR
23 = WRBG
24 = WRGB
25 = BWGR
26 = BWRG
27 = GWRB
28 = GWBR
29 = RWBG
30 = RWGB
31 = BGWR
32 = BRWG
33 = GRWB
34 = GBWR
35 = RBWG
36 = RGWB
37 = R
38 = G
39 = B
40 = W
41 = RG
42 = RB
43 = GB
44 = RW
45 = GW
46 = BW
47 = RGB
48 = RGW
49 = RBW
50 = GBW
51 = 6x (Kaleidoscope)
52 = 8x (Kaleidoscope)
53 = 12x (Kaleidoscope)
54 = Low (Quantization)
55 = Middle (Quantization)
56 = High (Quantization)
57 = Edges
58 = Edges Popup
59 = Emboss
60 = Emboss Popup
61 = Mirror H
62 = Mirror V
63 = Mirror D
64 = Mirror HV
65 = Mirror HD
66 = Mirror VD
67 = Mirror HVD
68 = Swap H 1x
69 = Swap H 2x
70 = Swap H 3x
71 = Swap H 4x
72 = Swap H 5x
73 = Swap V 1x
74 = Swap V 2x
75 = Swap V 3x
76 = Swap V 4x
77 = Swap V 5x
78 = Swap HV 1x
79 = Swap HV 2x
80 = Swap HV 3x
81 = Swap HV 4x
82 = Swap HV 5x
83 = Swap D 1x
84 = Swap D 2x
85 = Swap D 3x
86 = Swap D 4x
87 = Swap D 5x
88 = Swap HD 1x
89 = Swap HD 2x
90 = Swap HD 3x
91 = Swap HD 4x
92 = Swap HD 5x
93 = Swap VD 1x
94 = Swap VD 2x
95 = Swap VD 3x
96 = Swap VD 4x
97 = Swap VD 5x
98 = Swap HVD 1x
99 = Swap HVD 2x
100 = Swap HVD 3x
101 = Swap HVD 4x
102 = Swap HVD 5x
Choose the FX Filter of the Output.
13
Output Strobe
0 - 255
0 - 255
0 - 255
Ranging from slow to fast. 0 = Off.
14
Output Strobe Color Mode
0 - 255
0 - 255
0 - 255
0 = Output And Strobe Color
1 = Output And Black
2 = Black And Strobe Color
Choose the Color Mode of the Output Strobe.
15
Output Strobe Color Red
0 - 255
0 - 255
0 - 255
16
Output Strobe Color Green
0 - 255
0 - 255
0 - 255
17
Output Strobe Color Blue
0 - 255
0 - 255
0 - 255
18
Output Strobe Color White
0 - 255
0 - 255
0 - 255
19
Audio Output Level
0 - 255
0 - 255
0 - 255
20
Audio Input Level
0 - 255
0 - 255
0 - 255
21
Group Control Value Group #1
0 - 255
0 - 255
0 - 255
22
Group Control Value Group #2
0 - 255
0 - 255
0 - 255
23
Group Control Value Group #3
0 - 255
0 - 255
0 - 255
24
Group Control Value Group #4
0 - 255
0 - 255
0 - 255
25
Group Control Value Group #5
0 - 255
0 - 255
0 - 255
26
Group Control Value Group #6
0 - 255
0 - 255
0 - 255
27
Group Control Value Group #7
0 - 255
0 - 255
0 - 255
28
Group Control Value Group #8
0 - 255
0 - 255
0 - 255
29
Group Control Value Group #9
0 - 255
0 - 255
0 - 255
30
Group Control Value Group #10
0 - 255
0 - 255
0 - 255
31
Group Control Value Group #11
0 - 255
0 - 255
0 - 255
32
Group Control Value Group #12
0 - 255
0 - 255
0 - 255
33
Group Control Value Group #13
0 - 255
0 - 255
0 - 255
34
Group Control Value Group #14
0 - 255
0 - 255
0 - 255
35
Group Control Value Group #15
0 - 255
0 - 255
0 - 255
36
Group Control Value Group #16
0 - 255
0 - 255
0 - 255
Other Protocols
There are other preprogrammed DMX protocols you can choose from:
MADRIX 5.8.
