[1] Filter Color Red Deck A
[39] Filter Color Red Deck B
[75] Filter Color Red Main Output
[2] Filter Color Green Deck A
[40] Filter Color Green Deck B
[76] Filter Color Green Main Output
[3] Filter Color Blue Deck A
[41] Filter Color Blue Deck B
[77] Filter Color Blue Main Output
[4] Filter Deck A
[42] Filter Deck B
[78] Filter Color White Main Output
[PUSH 4] Filter Reset Deck A
[PUSH 42] Filter Reset Deck B
[79] Filter Main Output
[5] Filter Color Mode Deck A 'Allow Through'
[43] Filter Color Mode Deck B 'Allow Through'
[80] Blackout
[6] Filter Color Mode Deck A 'Filter Out'
[44] Filter Color Mode Deck B 'Filter Out'
[81] Master Value
[7] Filter Color Mode Deck A 'Colorize'
[45] Filter Color Mode Deck B 'Colorize'
[82] Audio Output Mute
[8] Not used
[46] Not used
[83] Audio Output Value
[9] Submaster Deck A
[47] Submaster Deck B
[84] Audio Input Mute
[10] Storage Place Deck A UP DOWN
[48] Storage Place Deck B UP DOWN
[85] Audio Input Value
[10 PUSH] Storage ID Deck A UP DOWN
[48 PUSH] Storage ID Deck B UP DOWN
[86] Main Output Strobe Color Red
[11] Layer Opacity Current Layer Deck A
[49] Layer Opacity Current Layer Deck B
[87] Main Output Strobe Color Green
[12] Speedmaster Deck A
[50] Speedmaster Deck B
[88] Main Output Strobe Color Blue
[13] Frame ID Deck A
[51] Frame ID Deck B
[89] Main Output Strobe White Blue
[14] Speed Pitch Storage Place Deck A DOWN
[52] Speed Pitch Storage Place Deck B DOWN
[90] Main Output Strobe Mode
[15] Speed Pitch Storage Place Deck A UP
[53] Speed Pitch Storage Place Deck B UP
[91] Main Output Strobe ON
[16] Speedmaster Pause TOGGLE Deck A
[54] Speedmaster Pause TOGGLE Deck B
[92] Main Output Strobe Value
[17] Storage Place Parameter Chaser Step Previous Deck A
[55] Storage Place Parameter Chaser Step Previous Deck B
[93] Fade Time 1/10 Sec
[18] Storage Place Parameter Chaser Step Next Deck A
[56] Storage Place Parameter Chaser Step Next Deck B
[94] Crossfader
[19] Storage Place Parameter Chaser Play/Pause TOGGLE Deck A
[57] Storage Place Parameter Chaser Play/Pause TOGGLE Deck A
[95] Fade Type
[20] Crossfader Fade To Left
[58] Crossfader Fade To Right
[21] Blind Current Layer Deck A
[59] Blind Current Layer Deck B
[22] Solo Current Layer Deck A
[60] Solo Current Layer Deck B
[23] Layer ID Deck A DOWN
[61] Layer ID Deck B DOWN
[24] Layer ID Deck A UP
[62] Layer ID Deck B UP
[25 Activated] + [29] - [36] Storage Place Deck A 1 - 8
[63 Activated] + [67] - [74] Storage Place Deck B 1 - 8
[26 Activated] + [29] - [36] Storage Place Deck A 9 - 16
[64 Activated] + [67] - [74] Storage Place Deck B 9 - 16
[27 Activated] + [29] - [36] Storage Place Deck A 17 - 24
[65 Activated] + [67] - [74] Storage Place Deck B 17 - 24
[28 Activated] + [29] - [36] Storage Place Deck A 25 - 32
[66 Activated] + [67] - [74] Storage Place Deck B 25 - 32
[37] Cue List Back
[38] Cue List Go
