▪Introduction
▪Overview
▪Context-Menu
▪Search
▪Options
▪Customization
The Log view shows all important occurrences of the MADRIX RADAR Software itself.
Such files are very helpful for technical support and assistance, but aren't necessarily required for the general use of the software. Still, it can provide you with valuable information and feedback for troubleshooting.
▪Severity - Allows you to filter only for specific kinds of information [including Info, Warning, Critical, Fatal].
- A specific severity level includes information for its own level as well as all higher levels.
Timestamp
Shows the local time when the status message occurred.
[YYYY/MM/DD HH:MM:SS]
[In contrast, log files are set to UTC time zone.]
Severity
Shows the classification for messages.
Module
Shows the software module [as information for the developers].
Message
Contains the contents and main information of the status message.
A maximum of 10,000 entries can be logged.
Context-Menu
Clear Log Messages
Removes all logged items from the list.
Show Log File Directory...
Opens the folder on your computer that holds saved log files.
[You can change the directory in the options »Logfile]
Copy Cell To Clipboard
Copy Rows To Clipboard
Copies the currently selected line or lines [that is, all parameter information] into the clipboard/temporary memory. [Keyboard shortcut: Ctrl + Shift + C]
Export List...
Search
▪Search - Enter any text in order to search all parameters in the list.
- For example: mess:IP shows all lines that include IP device information by referencing the column Message, for example.
Options
A new log file is created with each software start.
In addition, you can set up further settings for the Log in the Options.
Learn more »Logging
Customization
Timestamp
Shows or hides the Timestamp column.
Severity
Shows or hides the Severity column.
Module
Shows or hides the Module column.
Thread
Shows or hides the Thread column.
Message
Shows or hides the Message column.
Resize All Columns To Content
