AKAI Professional APC mini [MIDI map]
You Are Here:  Input, Interoperability, And Remote Control > MIDI [IN / OUT] >
General Overview
Mode
Active
Function
1
Deck A
2
Deck B
3
Group Control
4
Cue List
5
Timelines
8
Master
Sub-Mode
A
Mode Deck A: Place
Mode Deck B: Place
Mode Group Control: Group Value
Mode Cue List: Cue
B
Mode Deck A: Storage
Mode Deck B: Storage
Mode Group Control: Group Preset
Crossfader / Cue List Control
E
Mode Deck A: Fade To Left
Mode Deck B: Fade To Left
Mode Group Control: Fade To Left
F
Mode Deck A: Fade To Middle
Mode Deck B: Fade To Middle
Mode Group Control: Fade To Middle
Mode Cue List: Cue List Back
G
Mode Deck A: Fade To Right
Mode Deck B: Fade To Right
Mode Group Control: Fade To Right
Mode Cue List: Cue List Go
H
Mode Deck A: Auto Fade
Mode Deck B: Auto Fade
Mode Deck Group Control: Auto Fade
Mode Cue List: Cue List Play Pause Toggle
Flash Sub-Mode
I
As long as the button is pressed the Sub-Mode will be swapped.
Fixture Group Value
F1
Value Fixture Group 1
F2
Value Fixture Group 2
F3
Value Fixture Group 3
F4
Value Fixture Group 4
F5
Value Fixture Group 5
F6
Value Fixture Group 6
F7
Value Fixture Group 7
F8
Value Fixture Group 8
Master Value
F9
Value Output Master
Action Pads
Activates desired Place, Storage, Group Preset, Cue, sets the stored value for Groups or Main Output Parameters according to the following descriptions:
Detailed Description
Storage Places Deck A
(Mode: 1, Sub-Mode: A)
Button
Function
PAD 1 - PAD 64
Activate Storage Place at Deck A according to the PAD number.
B
Storage Control Deck A
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Storage Place is activated.
Content is saved at the Storage Place but it is not activated.
No content is saved at the Storage Place and it is not activated.
Storage Place is blocked.
Storages Deck A
(Mode: 1, Sub-Mode: B)
Button
Function
PAD 1 - PAD 64
Activate Storage at Deck A according to the PAD number.
A
Storage Place Control Deck A
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Storage is activated.
Storage Places with content are available at the Storage but it is not activated.
No content is available at the Storage and it is not activated.
Storage Places Deck B
(Mode: 2, Sub-Mode: A)
Button
Function
PAD 1 - PAD 64
Activate Storage Place at Deck B according to the PAD number.
B
Storage Control Deck B
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Storages Deck B
(Mode: 2, Sub-Mode: B)
Button
Function
PAD 1 - PAD 64
Activate Storage at Deck B according to the PAD number.
A
Storage Place Control Deck B
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Group Control - Values
(Mode: 3, Sub-Mode: A)
Button
Function
PAD 1 - PAD 8
Group 1 to Group 8 - Value 255
PAD 9 - PAD 16
Group 1 to Group 8 - Value 0
PAD 17 - PAD 24
Group 1 to Group 8 - Flash To Value 255
PAD 25 - PAD 40
Not in use.
PAD 41 - PAD 48
Group 9 to Group 16 - Value 255
PAD 49 - PAD 56
Group 9 to Group 16 - Value 0
PAD 57 - PAD 64
Group 9 to Group 16 - Flash To Value 255
B
Group Control - Presets
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Group Value activate.
Group Value not activate.
Not in use.
(Mode: 3, Sub-Mode: B)
Button
Function
PAD 1 - PAD 64
Activate Group Preset according to the PAD number.
A
Group Value
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Group Preset saved.
Empty Group Preset.
Cue Lists - Cue Selection
(Mode: 4, Sub-Mode: A)
Button
Function
PAD 1 - PAD 64
Activate Cue according to the PAD number.
B
Cue List Selection
F
Back
G
Go
H
Play / Pause Toggle
PAD Color
Meaning
Cue Playing.
Cue Available.
Empty
Cue Lists - Cue List Selection
(Mode: 4, Sub-Mode: B)
Button
Function
PAD 1 - PAD 64
Activate a Cue List according to the PAD number.
A
Cue Selection
F
Back
G
Go
H
Play / Pause Toggle
PAD Color
Meaning
Cue List activated.
Cue List available.
Empty
Timelines - Cue Segment Selection
(Mode: 5, Sub-Mode: A)
Button
Function
PAD 1 - PAD 64
Activate Cue Segment according to the PAD number.
B
Timeline Selection
G
Stop
H
Play / Pause Toggle
PAD Color
Meaning
Cue Segment playing.
Cue Segment available.
Empty
Timelines - Timeline Selection
(Mode: 5, Sub-Mode: B)
Button
Function
PAD 1 - PAD 64
Activate a Timeline according to the PAD number.
A
G
Stop
H
Play / Pause Toggle
PAD Color
Meaning
Timeline activated.
Timeline available.
Empty
Master - Main Parameter
(Mode: 8, Sub-Mode: A)
Button
Function
Speed Deck A
PAD 1
Deck A - Speed Up
PAD 9
Deck A - Speed Down
PAD 17
Deck A - Speed = 1.0
Speed Deck B
PAD 9
Deck B - Speed Up
PAD 16
Deck B - Speed Down
PAD 24
Deck B - Speed = 1.0
Output Master
PAD 33
Main Output Freeze
PAD 41
Main Output - Value Up
PAD 49
Main Output - Value Down
PAD 57
Main Output - Blackout
PAD 42
Audio Output - Value Up
PAD 50
Audio Output - Value Down
PAD 58
Audio Output - Mute
PAD 35
Auto Gain Control - On/Off
PAD 43
Audio Input - Value Up
PAD 51
Audio Input Value Down
PAD 59
Audio Input Mute
Fade Section
PAD 47
Fade Type - Up
PAD 55
Fade Type - Down
PAD 63
Fade Type - Crossfade
PAD 48
Fade Time - Plus 0.5 Seconds
PAD 56
Fade Time - Minus 0.5 Seconds
PAD 64
Fade Time - 0.0 Seconds
B
Color Filter
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Default Value, AGC, or Output Freeze is activated.
Value Up or Down, Default Value, AGC, or Output Freeze is available.
Blackout / Mute is activated.
Not used.
Master - Color Filter
(Mode: 8, Sub-Mode: B)
Button
Function
Color Filter Mode
PAD 1
Color Filter Mode - Allow Through
PAD 9
Color Filter Mode - Filter Out
PAD 17
Color Filter Mode - Colorize
PAD 25
Color Filter Mode - Ignore
Color Filter Colors
PAD 3
Filter Color Red - Value 255
PAD 11
Filter Color Red - Value 127
PAD 19
Filter Color Red - Value 0
PAD 4
Filter Color Green - Value 255
PAD 12
Filter Color Green - Value 127
PAD 20
Filter Color Green - Value 0
PAD 5
Filter Color Blue - Value 255
PAD 13
Filter Color Blue - Value 127
PAD 21
Filter Color Blue - Value 0
PAD 6
Filter Color White - Value 255
(available if Patch Color Depth = 4)
PAD 14
Filter Color White - Value 127
PAD 22
Filter Color White - Value 0
Strobe Mode
PAD 41
Strobe Mode - Output And Strobe Color
PAD 49
Strobe Mode - Output And Black
PAD 57
Strobe Mode - Black And Strobe Color
Strobe Colors
PAD 43
Strobe Color Red - Value 255
PAD 51
Strobe Color Red - Value 127
PAD 59
Strobe Color Red - Value 0
PAD 44
Strobe Color Green - Value 255
PAD 52
Strobe Color Green - Value 127
PAD 60
Strobe Color Green - Value 0
PAD 45
Strobe Color Blue - Value 255
PAD 53
Strobe Color Blue - Value 127
PAD 61
Strobe Color Blue - Value 0
PAD 46
Strobe Color White - Value 255
PAD 54
Strobe Color White - Value 127
PAD 62
Strobe Color White - Value 0
Strobe
PAD 48
Strobe Speed - Up
PAD 56
Strobe Speed - Down
PAD 64
Strobe
A
Main Parameter
E
Fade To Left
F
Fade To Middle
G
Fade To Right
H
Automatic Fade
PAD Color
Meaning
Activated.
Value available.
Not used.
MADRIX 5.7.
