MIDI Universal
MIDI Universal [MIDI Map]
Do not use MIDI channels/controllers that are currently not assigned. These entries are reserved for future features.
MIDI Message Type 0xb0 [Controller 0xb, Channel 1]
Controller
Value
#00
Storage Place Left
#01
Storage Place Right
#02
Storage Place Left +Fade
#03
Storage Place Right +Fade
#04
Storage Place Left UP
#05
Storage Place Left DOWN
#06
Storage Place Right UP
#07
Storage Place Right DOWN
#08
Storage Place Left UP +Fade
#09
Storage Place Left DOWN +Fade
#0A
Storage Place Right UP +Fade
#0B
Storage Place Right DOWN +Fade
#10
Storage Place Submaster Left
#11
Storage Place Submaster Right B
#12
Storage Place Submaster Left UP
#13
Storage Place Submaster Left DOWN
#14
Storage Place Submaster Right UP
#15
Storage Place Submaster Right DOWN
#20
Speed Master Left
#21
Speed Master Left UP
#22
Speed Master Left DOWN
#23
Speed Master Left Reset
#24
Speed Master Left Pause
#25
Speed Master Left Pause (Hold)
#26
Speed Master Left Play
#28
Speed Master Right
#29
Speed Master Right UP
#2A
Speed Master Right Down
#2B
Speed Master Right Reset
#2C
Speed Master Right Pause
#2D
Speed Master Right Pause (Hold)
#2E
Speed Master Right Play
#30
Storage Left Frame ID UP
#31
Storage Left Frame ID DOWN
#32
Storage Right Frame ID UP
#33
Storage Right Frame ID DOWN
#3A
Main Output Freeze ON
#3B
Main Output Freeze OFF
#3C
Main Output Freeze (Hold)
#40
Layer Left
#41
Layer Right
#42
Layer Left UP
#43
Layer Right DOWN
#44
Layer Right UP
#45
Layer Right DOWN
#50
Layer Opacity Left
#51
Layer Opacity Right
#52
Layer Opacity Left UP
#53
Layer Opacity Left DOWN
#54
Layer Opacity Right UP
#55
Layer Opacity Right DOWN
#60
Layer Submaster Left
#61
Layer Submaster Right
#62
Layer Submaster Left UP
#63
Layer Submaster Left DOWN
#64
Layer Submaster Right UP
#65
Layer Submaster Right DOWN
#70
Layer Mix Mode Left
#71
Layer Mix Mode Right
#72
Layer Mix Mode Left UP
#73
Layer Mix Mode Left DOWN
#74
Layer Mix Mode Right UP
#75
Layer Mix Mode Right DOWN
MIDI Message Type 0xb1 [Controller 0xb, Channel 2]
Controller
Value
#00
Layer Frame ID Left UP
#01
Layer Frame ID Left DOWN
#02
Layer Frame ID Right UP
#03
Layer Frame ID Right DOWN
#10
Crossfader Fade Time
#12
Crossfader Automatic Fade
#13
Crossfader
#14
Crossfader Step Left
#15
Crossfader Step Right
#16
Crossfader Skip to Left
#17
Crossfader Skip to Right
#1A
Master
#1B
Master UP
#1C
Master Down
#20
Crossfader Fade Type UP
#21
Crossfader Fade Type DOWN
#22
Crossfader Fade Type Cross-Fade
#23
Crossfader Fade Type White-Fade
#24
Crossfader Fade Type Black-Fade
#25
Crossfader Fade Type Color-Fade
#40
Color-Fade color RED
#41
Color-Fade color RED UP
#42
Color-Fade color RED DOWN
#43
Color-Fade color GREEN
#44
Color-Fade color GREEN UP
#45
Color-Fade color GREEN DOWN
#46
Color-Fade color BLUE
#47
Color-Fade color BLUE UP
#48
Color-Fade color BLUE DOWN
#49
Color-Fade color WHITE
#4A
Color-Fade color WHITE UP
#4B
Color-Fade color WHITE DOWN
#50
Cue Storage Place Left
#51
Cue Storage Place Right
#52
Delete Cue List Entry VALUE
#53
Delete CURRENT Cue List Entry
#54
Cue List Play
#55
Cue List Stop
#56
Cue List Play/Pause
#57
Cue List Go
#58
Cue List Back
#59
PLACEHOLDER
#5A
Cue List Goto
#5C
Cue List Open
#5D
Cue List Close
#5E
Cue List Open/Close
#60
Audio Input ON
#61
Audio Input OFF
#62
Audio Input ON/OFF
#63
PLACEHOLDER
#64
PLACEHOLDER
#65
PLACEHOLDER
#66
Audio Input Level
#67
Audio Input Level UP
#68
Audio Input Level DOWN
#70
Color Filter color RED
#71
Color Filter color RED UP
#72
Color Filter color RED DOWN
#73
Color Filter color GREEN
#74
Color Filter color GREEN UP
#75
Color Filter color GREEN DOWN
#76
Color Filter color BLUE
#77
Color Filter color BLUE UP
#78
Color Filter color BLUE DOWN
#79
Color Filter color WHITE
#7A
Color Filter color WHITE UP
#7B
Color Filter color WHITE DOWN
MIDI Message Type 0x80 [Note OFF]
#0
Storage Place Left P1 +Fade
#60
Storage Place Right P1 +Fade
#59
Storage Place Left P60 +Fade
#119
Storage Place Right P60 +Fade
#124
Storage Place Left +Fade DOWN
#126
Storage Place Right +Fade DOWN
#125
Storage Place Left +Fade UP
#127
Storage Place Right +Fade UP
MIDI Message Type 0x90 [Note ON]
#0
#60
#59
#119
#124
#126
#125
#127
You can get an overview over all preprogrammed MIDI maps in the chapter »MIDI-IN
MADRIX 3.6i
