Elation Professional MIDICON [MIDI Map]
Elation Professional MIDICON - MIDI Map
[3] Cue Storage Place Left
[52] Speed Master Right Pause
[8] Cue Storage Place Right
[56] Cue List Open/Close
[11] Layer Left DOWN
[57] Cue List Play/Pause
[12] Layer Left UP
[62] Storage Place Left UP (Arrow key behavior)
[13] Color-Fade color RED (ON/OFF)
[64] Storage ID Left DOWN
[14] Color-Fade color GREEN (ON/OFF)
[65] Storage ID Left UP
[15] Color-Fade color BLUE (ON/OFF)
[67] Storage Place Right UP (Arrow key behavior)
[16] Color-Fade color WHITE (ON/OFF)
[69] Storage Place Left LEFT (Arrow key behavior)
[17] Layer Right DOWN
[70] Storage Place Left DOWN (Arrow key behavior)
[18] Layer Right UP
[71] Storage Place Left RIGHT (Arrow key behavior)
[19] Layer Left Solo Mode
[72] Storage ID Right DOWN
[20] Layer Left Mix Mode UP
[73] Storage ID Right UP
[25] Layer Right Mix Mode UP
[74] Storage Place Right LEFT (Arrow key behavior)
[26] Layer Right Solo Mode
[75] Storage Place Left DOWN (Arrow key behavior)
[27] Layer Left Blind Mode
[76] Storage Place Left RIGHT (Arrow key behavior)
[28] Layer Left Mix Mode DOWN
[77] Speed Master Left UP/DOWN
[33] Layer Right Mix Mode DOWN
[77 Push] Speed Master Left Reset
[34] Layer Right Blind Mode
[78] Crossfader
[35] Blackout
[78] + [89] Crossfader Fade Time UP/DOWN
[36] Layer Left Opacity
[78] + [91] Audio Input Level UP/DOWN
[37] Layer Left Submaster
[78 Push] Crossfader Automatic Fade
[38] Color Filter color RED
[79] Speed Master Right UP/DOWN
[39] Color Filter color GREEN
[79 Push] Speed Master Right Reset
[40] Color Filter color BLUE
[80] Speed Master Left Pause (Hold)
[41] Color Filter color WHITE
[82] Crossfader Skip to Left
[42] Layer Right Submaster
[83] Crossfader Skip to Right
[43] Layer Right Opacity
[85] Speed Master Right Pause (Hold)
[44] Master
[86] Main Output Freeze (Hold)
[45] Speed Master Left Pause
[87] Main Output Freeze (Permanently)
[48] Cue List Go
[88] Crossfader Fade Type DOWN
[49] Cue List Back
[90] Audio Input ON/OFF
You can get an overview over all preprogrammed MIDI maps in the chapter »MIDI-IN
