Export From MADRIX 2.X To MADRIX 3.X
How To Convert MADRIX 2 Setup Files Into MADRIX 3 Setup Files
MADRIX 3 uses its own file types. Please follow these steps to convert your MADRIX 2 Setup File into a MADRIX 3 Setup File:
Install MADRIX 2.14h.
Start MADRIX 2.
Load your the Setup File of the file type *.ms2 you wish to convert. Go to "File" -> "Open Setup...".
Go to "File" -> "Export" -> "Export for MADRX3..." -> "Setup...".
A new window opens. Simply enter a name for the file and click "Save".
Start MADRIX 3 and load your newly created MADRIX 3 Setup File of the file type *.msz. Go to "File" -> "Open Setup...".
How To Convert MADRIX 2 Fixture Library Files Into MADRIX 3 Fixture Library Files
MADRIX 3 uses its own file types. Please follow these steps to convert your MADRIX 2 Fixture Library into a MADRIX 3 Fixture Library:
Start the MADRIX 2 Fixture Editor.
Load the fixture library of the file type *.mfl you wish to convert. In the Fixture Editor, go to "File" -> "Open Library...".
In the MADRIX 2 Fixture Editor, go to "File" -> "Export Library for MADRX3...".
You can now load this *.mflx file with the MADRIX 3 Fixture Editor or use it for MADRIX and load it in the Startup Options, for example.
