       SCE Pulse/Stroboscope  |
 The SCE Pulse/Stroboscope produces a stroboscope or pulsating effect. Enable this effect to generate regular flashes. Strobe lights are often used in nightclubs and raves, and are available at home for special effects or in the entertainment area. "Frequency" (frequency) determines the flash interval in "Pulse" mode. Sequences can vary from very slow speed (a value of 1) to a very high velocity (a value of 25). Use the "Tap" button to manually adjust the Frequency. Tap at least four times in order to input it correctly. In "Strobe" mode you can select the time, the effect switches "On" and "Off". If you want the effect to be rendered more smoothly, press the "Fade" button ("Set frame fade").  |
