SCE Drops
SCE Drops
The SCE Drops effect displays falling objects, just like rain drops.
As always, the input field "BPM" sets the speed of the effect. You may enter a value between 1 and 9999.
SCE Drops Example
"Step" can be used to stretch the drops. For example, a step value of 2 will render drops every second pixel. With "Length" you can choose the length of the single objects. Adjust the number of objects by using "Count". "Width" sets the width of each object, while "Pitch" determines the spacing between objects.
Arrow Buttons Four arrow buttons allow you to decide in which direction the effect should move.
In addition, you can choose from different shapes. Click the button labeled "Line" by default.
Use the "Color Table" to set up the colors of the effect. In addition, those colors can be used in chronological order or shuffle mode. Entirely random colors can be used, too.
Color TableTo set up the Color Table, please click the button. A new window containing a list of colors will appear. You can enter numerical values from 0 to 255 for red, green, blue, and white via input fields. You can extend your list with a new color value by pressing the "+" button. Existing entries can be deleted from the list by marking it and pressing the "-" button. The order of your entries (colors) may be changed, too. In order to do so, simply select the color and press the upward arrow or the downward arrow.
The list you created as well as presets can be saved and loaded. The number of entries in the list can be seen in the lower part of the window. In our example shown above, six entries are currently included in the list (#6). To close the window, click "Close".
