SCE Explosions
SCE Explosions
The SCE Explosions effect can display all kinds of explosions and fireworks.
SCE Explosions Example
The Color Table defines the colors used by the effect.
"BPM" defines the speed of the effect.
"Size" defines how big the whole explosion will be.
"Shape Size" defines how big single objects are.
"Explosions" defines how many explosions are displayed by the effect at the same time.
"Shapes" defines the number of single objects a single explosion includes.
"Fade Out" defines if objects get a visual tail and fade out over time.
"Gravity" defines how strong objects are dragged to the bottom.
"Sparkle" defines which color is added to single and small parts of the explosion.
More ControlsYou can choose from two different modes: Explosions and Fireworks. If Fireworks is selected, you may also define a direction will the help of the four arrow keys. You can also choose from different types of explosions (Sphere, Sphere Glow, Spiral, Radial, Diamond, Star, or Random). You can also choose from different shapes for the objects (Rectangle, Rectangle Filled, Circle, Circle Filled, Cross, Star, Diamond, Diamond Filled, or Random).
